WD Rear Power Adjust Cams and clamps
TwoWheelsNow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TwoWheelsNow Quote  Post ReplyReply Direct Link To This Post Topic: WD Rear Power Adjust Cams and clamps
    Posted: 06 Jul 2016 at 5:50am
Hi:
My new-to-me WD has apparently had one rear wheel replaced at some point. One wheel has holes drilled in the ramp parallel to the AXLE, with angled clamps (Which I believe is original style?), but the other has holes drilled perpendicular to the ramp itself, which presumable uses straight clamps.
a) where can I find the straight clamps, and what do the look like? Is this the Massey style?
b) the cam-bolts used to clamp the wheel before installing the stops are a mess. Some of them are siezed in place, and some move but dont seem to stop the wheel from self-adjusting. What do these look like, and how are they replaced? Can it be done without removing the rim?
Thanks,
Dave
Edited by TwoWheelsNow - 06 Jul 2016 at 5:51am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 11:50am
You need to separate the wheel center from the rim to fix up the eccentrics.  It's not unusual for them to get rusted and seized up.  I put all mine in the wood stove all night in the winter to get them loosened up.  After that I was able to take everything apart and clean things up.
If your wheel is moving in and out, that is a sign they are not tight.  IF you tighten the bolt head, that should hold the rim in place.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 12:56pm
 If they're run loose for long periods of time, they tend to wear the rails that they ride on, too.   Rick
