6060 followed me home
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Topic: 6060 followed me home
    Posted: 25 Jun 2016 at 11:41am
OK, so I pulled the trigger, a grand less than I expected.  The lights even worked and I was sold.  Have not gotten the Owners and Service Manuals but they come with the tractor. Tractor is clean and paint is bright, appears to have been stored under cover. New on a potato farm and was only used on a potato digger the last 5 years.  No caked on manure!
Left brake sticks down, you have to pry it up with your toe.  I am presuming that if I take the front panel off I will find the brake assembly, and am hoping is is just in need of lubrication?  The brake pedals are not bent of damaged in any way, just the inside one sticks....they both work.  Parking brake light does not work.
The clutch is at the high end, but I could not get it to slip in H4 with the brakes on.  I am hoping it is just in need of adjustment?
There was a hum in high range when starting out, seemed to be in all gears?
PTO lever was in the forward position and I was told it worked properly. It has the thrust bearing bra installed.  Slight oil leak at one bolt holding bra on.  Hoping loose bolts.
Bill  and my last name is Allis
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2016 at 10:35pm
I bought a 6080 that had been sitting a while and both brake pedals were almost frozen solid, very hard to move.  I pulled the snap rings and with a lot of penetrating oil and pushing and pulling I got both pedals worked out.  Before you take them out measure the height of the pedal so you get it splined up at the same height(there is a measurement for that in the manual). Sanded the pedal shafts and honed the mount they slide into.  Now it is like power brakes, very light pedal will stop the tractor instantly.  I replaced the clutch due to the front trans seal leak and it does seem to engage on the high end of pedal travel.  It is adjusted perfect, must be the way it is.  I pulled a disc with it the other day and it would loose traction, never had any slippage.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2016 at 6:21am
PTO big stick stay forward all the time unless you are using it to disengage the running PTO. Pulling it back puts pressure on the thrust block.
Clutch engagement is on the side with cable adjuster. Supposed to have 1.5" of play
Pictures!
Charlie
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2016 at 6:58am
Happy for you
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2016 at 7:13am
Don't have it home yet, will take some pictures then.  They had been using the tractor to haul and unload hayilage. Said the PTO worked fine.  It was in the right position and both levers  seemed to engage properly.  Hopefully the brake issue will be a cheap fix.   Any idea on the hum in high range?  Normal or might it be low on transmission oil.  I did not fine a dip stick for the trans/hyd, haven't read the books yet.
Thanks for the information... keep is coming.  This is just a toy to mow 10-20 acres and till 5 to 10.  But I don't need problems.
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2016 at 8:21am
The trans doesn't have a dipstick just a plug on the right side to check fluid level.  It takes 3 gallons for it.  The rear housing does have a dipstick, it is set in a little indentation so clean out before you unscrew it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2016 at 8:22am
Not sure about the range hum, but the hydraulics do hum
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2016 at 8:30am
Tranny plug is on tranny housing slightly forward and below the brake pedals. Clear as mud?
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2016 at 12:52pm
Just like LBO442 said the brakes will be a cheap fix, just need to take it apart, clean it and grease it. Mine was the same way when I got it, RH pedal would stick down and had to lift it with my foot. If it has a cab that makes it a little more difficult but still not too bad. Just need to be careful not to break the lower RH side glass when removing brake pedal shaft. You'll like the tractor once you get her all tuned in to your liking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 2:55pm
Ok my description was off looked today directly below brake pedals. Takes roughly 1 1/8 socket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 9:44pm
Bill here is some pages from the service manual that should help with the brake pedals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 6:46am
The pictures make sense.  Couldn't understand how the valve actuated.  Now it makes more sense.  Did you take it all apart or just work lubricant into the bushings?
Thanks again,  supposed to be getting oweners and service manuals with the tractor, that will help... will know tomorrow.
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 8:36am
I took the pedals all the way out, cleaned and lubed.
