D17 dist gear-worm gear lubrication?
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: D17 dist gear-worm gear lubrication?
    Posted: 15 May 2010 at 2:29pm
How is the distributor gear and worm gear lubricated, and also the hole  towards the top of the dist that has a plug that is removable whats it for and what lube do you use in it assuming it is for lubrication.  My neighbor has a wasted out wc the engine i think is loose other wise very poor does it have a value? thanks
