C/A hi/lo range
JoeK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeK Quote  Post ReplyReply Direct Link To This Post Topic: C/A hi/lo range
    Posted: 13 May 2010 at 7:49am
Just brought my 1955 ca to her new home on sat. this is the same tractor I drove 42 years ago when I worked in the celery fields. The original owner called and wanted me to have it, now it's mine. Don't know where to start, needs paint everything else works great! The front rims are solid creme colored, is that correct for that year?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 8:40am
It's your tractor so whatever you want is correct!  The actual correct color would persian orange #1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 8:46am
Front rims were Orange, back rims were galvanized and back wheel centers were Orange. Everything else was orange except the rubber tires, the light lenses, and the muffler. Good luck with a great tractor.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 9:07am
What is the Hi/lo range you are referring to?
Charlie
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 9:28am
sherman transmission
Farm stuff 8050,6690,175,F2,5050,WD
JoeK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 9:53am
When driving in hi range and 4th gear you better have your hat on lock, that thing goes!!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 10:18am
Now that sherman made atractor out of it, I bet. 8 speds forward and 2 reverses. Allis should have done that to all their tractors.
