WD hand clutch
brenpak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Topic: WD hand clutch
    Posted: 07 Mar 2016 at 7:02am
Is there a way to adjust the hand clutch so it is not so sensitive
I mean as soon as I pull the handle back a little it starts to move forward real quickly Just asking Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2016 at 7:29am
Make sure the compartment is full of oil. Other than that, you may just have to get used to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2016 at 7:32am
Ok I can understand that the WD is new to me so maybe I have to baby the hand clutch
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2016 at 10:52am
You could pull the pin at the bottom of the Lever, loosen the lock nut, and turn the yoke a few turns to shorten the Rod.
That way the Lever should have some extra free travel before the clutch starts to engage.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2016 at 11:29am
Ok I will try that thank you
