Straight Pipe
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Straight Pipe
    Posted: 02 Mar 2016 at 1:10pm
I am going to straight pipe my D 15 II with a double wall that turns 90 degrees at the top.  This is not a working tractor and will only be on one tractor ride a year and maybe push a little show.
Anyhow I cannot get a grip on what size outlet would look appropriate.  The most readily available one I see is 3 inch, but i think it would look scrawny.
What size do you folks that have eyeballed them installed looked appropriate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 2:38pm
Since you're the one that'll have to look at it and ride it once a year, you should spend some time and mockup  a few 'mufflers' from say 1 1/2, 3" and 4" ABS pipe and a few adapters. Dry fit, then when 'happy', spray with silver rattle can. Walk around it, take a few pictures....go back into house..put pix on PC and look again.
Jay
Brian-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 3:17pm
My guess is a 3" would look pretty beefy on a D15.
I think my 190 came from the factory with a 3" pipe.
EAT BEEF!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 9:12pm
My thoughts exactly.  Any thing bigger than 3" would be alright on a 190, but on a little D15?  3" would be more than enough I think.
With no muffling ability, that straight pipe is really going to make that tractor snort on a ride or parade!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 7:33am
thanks for the input guys, I am going with a 3 inch.
I don't know about the sound on the double walls.  I just been slipping a pipe on the manifold for the initial run up and test ride.  It was well within the bearable range for me, not pulling of course.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 8:41am
Yep,,,3" will look nice and,,,,I know it's gonna sound "raspy,snarly and get out the way",,,Tough,,,,!!!
Just call it " The Straight Pipes Special",,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 2:07pm
The guy at the back of the line will probably be looking for earmuffs by the end of the ride. Why not just put the correct muffler on it so everyone can enjoy a nice ride through the without having their ears ringing after a couple hour ride?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 2:08pm
can point the slant to the front!
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 6:36am
I guess you're not concerned with efficiency or power, but no back pressure (free flow) will decrease the engine efficiency.
At least it did on my B.
This page was generated in 0.089 seconds.
