Removing 60 header
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Removing 60 header
    Posted: 19 Jan 2016 at 7:28pm
I need to remove the header on one of my 60 all crops. How do you go about removing one?
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 7:42pm
Tie it to a tree . And away you go !!!!
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 7:46pm
LMAO!!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 7:57pm
LMAO!!
   X2!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 8:15pm
Everybody is a comedian!!
I'd rather keep the rest of the machine in decent shape. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 8:19pm
In that case you might want to spray a little PB blaster on the hinge point so it lets go a little easier.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 7:08am
Its pretty straight forward.
Disconnect the pitman from the sickle
Disconnect the lift linkage
Pull out the lower draper upper roller at the top of the header.
If I missed something guys please advise
Only gotcha I have is the pully on the roller can be a SOB to remove as
it is on a tapered shaft and can be stuck on there good. When using a gear pulley you could bend the sheaves. Take the grain tank off and you can pull it out without taking the sheave off, but I wouldn't recommend that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 8:46am
That was my one worry about that pulley. Looks like it has six bolts around it and one in center. Which one needs removed. The six, or the one in center?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 8:57am
I have no idea ...BUT I would oil everything that 'looks' like a connection, then try tomorrow.
Waiting a day will allow the oil to 'do it's thing' and maybe someone will chime is what else needs to be done.
Just be real careful ! block things up, look 2,3 times BEFORE you yank and bust something.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 9:00am
Someone put it together 60 years ago so It will come apart. But as mentioned some parts may have grown together with age.
We ever had to take one of these apart on the farm. Pulleys can be tough.
 I dont have a picture of the pulley. But sometimes you can drill a couple 3/8 holes near the hub and get some bolts/nuts through those and use them as a puller against a plate, with corresponding holes, across the end of the shaft? Just a thought. I have seen this done on Cub Cadet front PTO pulleys which are a bugger sometimes. Pulling on the outside of a thin pulley is asking for trouble.
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 3:13pm
Take the pulley off and pull from the hub.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 3:18pm
Looking at the illustration you cant take it off..it sits behind the hub, not in front. HOWEVER if it can be shoved back a little once disconnected perhaps enough room to clamp on to the hub
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 8:17pm
Once you have it moved back you can pull it off otherwise remove the nut from the shaft put a pry bar behind the hub and pulley and hit the shaft after you have the shaft threads covered with a block of wood. Should pop off.
