CA hand clutch
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Topic: CA hand clutch
    Posted: 08 Jan 2016 at 1:49pm
How does the hand clutch work? I have a service manual, but what does the handle move to release the clutch? I think the springs are to short.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 5:26pm
It releases the clutch allowing the shaft to spin
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 6:29pm
It's a Lambert set up I believe. Like the Lambert brakes on a VAC Case kinda. There are ball bearings set in a teardrop shaped groove. When you pull the handle, the balls climb up to the narrow end of the groove and push the clutch out to release.
 This post might help.
 http://www.allischalmers.com/forum/forum_posts.asp?TID=12941&title=ca-hand-clutch
