wheel bolt pattern on rotobaler?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: wheel bolt pattern on rotobaler?
    Posted: 27 Apr 2010 at 6:20am
What is the bolt pattern on the wheels of a rotobaler and does it match up to any other AC stuff.   From the few pictures I have looked at, it looks like a 6 hole bolt pattern like on the 6 bolt rims on my D15 or D17.  Just wondering if I considered to pull one home, what tires I could bring along for spares in case one blows out on the way.
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 7:24am
Should be standard six bolt, any AC combine or picker should be same. Fred
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 7:46am
Yep standard 6 lug implement wheel. I want to say that there is 6 inches when measured across between 2 lug holes. I took wheels off an old hay rake, but I had to grind the center hub hole out a little to get them to fit.
