One row cultivator
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: One row cultivator
    Posted: 25 Apr 2010 at 10:33pm
I am thinking of buying a B to cultivate the garden in the near future. I would like to cultivate one row at a time. How hard is it to find one row cultivators? How is a B for cultivation?
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 11:56pm
I think this is the same as the D10?
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 6:44am
I have a one row B cult. $150.00 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 2:08pm
Where are you at Ray? Thanks.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 8:06pm
Here is a one row cultivator on a B at "Coming Home" Union Bridge, WI.
Take good care of my favorate.
Good Luck!
Bill Long
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 8:09pm
This is the older style B cultivator.  Never used it, some say the B was a bit too fast for fine truck garden work.  I still have not found the old style shovels I have some that are OK for show.
Edited by Rick of HopeIN - 26 Apr 2010 at 8:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 8:46pm
I have the exact same set that Rick has.  I used it last year for the first time to cultivate a small tract of sweet corn.  I think it worked pretty good.  The only thing that I saw as a negative is I think the clearance underneath the B might be less then the clearance underneath a WD, so you could cultivate with them a little later in the year I think.  I'm no expert though.  Last year was my first year that I ever cultivated something.  I now have a set for my WD, and I was going to use that this year.  I am going to send you a PM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 8:59pm
Rick, I think that is the first B I've seen with the B decal that should have a B decal. What year is it? Must be after the CA came out cause of the taped holes in the torque tube.  Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 9:00pm
I never cultivated until wide front tractor and rear cultivator was standard.  We seldom went into the fields after the stuff was over a 18" tall anyway.   Clearance under a wide front axle is not that much even on large tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 9:02pm
Jesse, Ray is in Beattie, Kansas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 9:03pm
she's a 1951.  Original fender had a bullet lamp too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 5:58am
Thanks guys. I am on the lookout for a cultivator. I need to cut down on some of the labor in the garden.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 6:04am
I had complete sets of cultivators go for scrap at my auction recently, including a B one row cultivator. Gone forever
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 8:26pm
I ran across a set on a sale wagon once for $25.  Was far away and driving a Corolla that day.
firetech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firetech Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 9:23pm
Guys I'm also looking for a cultivator for my B.  I live in mid Mich so trying to keep it to a couple hour drive. Thanks for the help. Herb
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:09am
I would like to find cultavatorsfor my D14. 864-934-4393. Thanks, Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 11:23am
I may try and find a set for my CA. I already have that and it may be cheaper in the long run. I just hate pulling the mower deck out from under it. Maybe a B for my mower and my CA for field work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 1:05pm
If you mow with the CA no you won't like the B so much for mowing. Just by another CA with the cultivator. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 2:30pm
A late B is almost the same engine correct? Whae else would make it worse for mowing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 3:09pm
The gearing is different. I could mow in 1st 2nd or 3rd with the CA depending on conditions. The B is almost too fast in 1st for some things and is too fast in 2nd for most mowing. I also have a narrow front CA and it is a big change to go to the wide front B with the same mower. It doesn't turn as short without skidding the front.
