Model identifaction
Reconone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reconone Quote  Post ReplyReply Direct Link To This Post Topic: Model identifaction
    Posted: 21 Apr 2010 at 9:51pm
I just purchased my first Allis Chalmers and have no idea what model it is.  It is going to need many, many parts so knowing what I have must come first.  Where should numbers, etc. be located?  I just need a little push to get started bringing this item back to life.  thanks in advance.
Larry
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2010 at 9:56pm
Can you post a picture? Is it a wide front, narrow, gas, diesel, how many speeds in tranny. Without a little more info. it's hard to tell you where to look for a serial #.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2010 at 10:12pm
Depending on what model and what/how many parts are missing you may be better off buying another tractor of the same model and using that tractor as a parts tractor...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 7:35am
From the late 30's till the late 50's the serial number would be stamped next to the gear shift lever or on the back of the differential housing behind the left brake. All models stamped by the shifter will start with the model, such as B12345 or C12345 or CA12345.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 7:47am
    If it looks anything like this, it could be a WC,WD or a WD45.
If it looks like this one, it needs weight on the front. LOL This is an early  B.
 aaaa
