Switching out PTO's on a 185
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Switching out PTO's on a 185
    Posted: 14 Apr 2010 at 6:37am
I know that this has been talked about before, but I will be needing to do a complete rebuild from front to back on my 185 sometime in the future.  It needs third gear changed, and probably some bearings in the rear end.  Since I will have it apart, is it feasable to install a 540/1000 rpm unit in it?  Thanks for the help.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 9:11am
No problem changing it over, you will need to put the 1000 gear in the pto clutch, I have everything you need if your interested. Thanks, Kevin in Washington State.
dennyh(oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dennyh(oh) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 9:48am
MY 185 HAD A REVERSABLE 540/1000 P.T.O. I THINK YOU JUST TOOK THE BOLTS OUT OF THE P.T.O., PULLED IT OUT, TURNED IT END FOR END AND BOLTED IT BACK IN AND YOU WERE READY TO GO.
