Wd and CA attachments
dewn81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dewn81 Quote  Post ReplyReply Direct Link To This Post Topic: Wd and CA attachments
    Posted: 30 Jun 2015 at 12:43pm
Will wd snap-coupler attachments work on a Ca with a snap-coupler system?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 1:00pm
The lift arms of the CA are about 3" narrower. On a fixed width like sc blade, you will have to modify.
Leon B
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2015 at 4:15pm
Most attachments will work
Thanks & God Bless
Dennis
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 10:18am
Some attachments, like the No. 7 mower and the rear carrier would fit either the WD/WD45/D14/D15 or the CA/D10/D12. They had offset lift linkages that you could swap from side to side to fit either lift arm spacing. The AC rear blades did not have this feature and need some simple modifications to adapt from one lift arm spacing to the other.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 10:20am
On snap-couplet plows and some other attachments, there may also be a difference in the drawbar length (part that hooks into the bell under the tractor).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2015 at 6:45pm
Yes they are different but I have had no issues.
Thanks & God Bless
Dennis
