45 Pulling tractor |
Post Reply ![]() |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
![]() ![]() ![]() ![]() ![]() Posted: 27 May 2015 at 6:23am |
What do you all think about this tractor?
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
What motor is in it? 3 carb setup must be fun to sync.
Charlie
BPM75 ![]() Orange Level ![]() ![]() Joined: 11 Jun 2011 Location: Greenup IL Points: 1050 |
I'm not sure what motor it is, but wow they done a nice job on that tractor, very clean and well built.
59 D17 gas nf, 66 XT 190, 69 220.
That intake/header exhaust is a mint!
Is it a 292 motor?
Charlie
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
If I remember it's a modified 302 GMC
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
VFDfireman ![]() Silver Level ![]() ![]() Joined: 11 Jan 2013 Location: South Dakota Points: 414 |
Is the handle on the right fender the throttle?
Not familiar with pulling tractors... |
Yes the throttle is on the right fender. It's called a deadman as it is spring tensioned so that if you let go it pulls back so that the tractor does not "run away"
Man that header is a thing of beauty!
Charlie
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3896 |
im sure somone on here will know whos it is does look sharp
Description says engine is a 1952 525 cid
acd21man ![]() Orange Level ![]() ![]() Joined: 07 Jan 2010 Location: tn Points: 831 |
wounder how many plows it can pull lol .
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
What class would that pull in?? Most non-turbo classes have an rpm limit and stock block rules. I don't know what stock WD45 block could be opened up to 500+ cu. in. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Brian-KS ![]() Orange Level ![]() Joined: 27 Aug 2014 Location: Kansas Points: 914 |
Looks Good
EAT BEEF!
wait it cant be a gmc 302 the ex and air intank is in the other side of the block right??
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6066 |
Well... unless they mounted the engine backwards... and they could have...
water pump is still in the front. and timing cover
iv been lookin for about a hour know lol i give up im going to bed ha Edited by acd21man - 27 May 2015 at 10:56pm |
Perhaps and RD-501... with a taller valve cover?... nahh... lower block has curves around each cylinder. Hmmm...
I didn't even pay attention to which side they were...thought I had read it awhile back
7700 and a few mins left any1 guna bid on it lol
figured it out its a 503 gmc. i was wrong:(. didnt no they made them. look them up
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5085 |
That's a slick tractor. Didn't sell at 9200
I contacted him about the engine.
This is what he wrote back: 1952 gmc 800 class firetruck factory 503 ci, now 525 ci, stock stroke. |
EAT BEEF!
Again, I wonder where you would find a class that you could pull that in (other than the mod classes where that engine wouldn't be competitive). |
Mark
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
I have a GM 235 CID in mine, but haven't run it yets!
Post Reply ![]() |
