Synthetic oil
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Topic: Synthetic oil
    Posted: 20 May 2015 at 6:36am
Synthetic oil concept of suspending the bad particles so the filter can safely remove them, thus making the oil last longer I can understand, but it synthetic oil really beneficial in a 2 stroke, since it's just getting burned?
I still gots my A/C but it's clear out in the barn now.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 6:47am
I don't know as I have been burning the Wally Worlds  tech 200 stuff for years.
My Stihl chain saw even dines on that stuff without indigestion. Smile
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 8:22am
kinda spensive that way isn't it Les?
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 9:00am
Without getting into the science of what makes a synthetic a synthetic, I will say the following:
1. The countertop commando at your parts store doesn't know jack about greases and oils other than what sales marketing literature he or she has read.
2. "Synthetic" these days for the most part, are nothing more than a conventional oil with a different refining process.
3. Synthetic oils don't suspend particles better than any other oil....
IMO use what meets the required specification and has the least impact on your wallet.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 9:46am
Wrong on number 2, VFDfireman. Castrol did claim their super refined mineral oil base stocks were "synthetic", but I think they've switched to engineered base stocks now. Correct on the other two. As for two cycle. AMSOIL makes two stroke synthetics. How much does it matter when you consider that it goes through the engine once and is then burned and exhausted? I dunno.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 10:21am
If you use a QUALITY 2 stroke oil, you can safely go leaner on the oil. Some engines do very well on 100:1, as opposed to many that require 20:1 on mineral oil. Some injected engines use even less. The real benefit of a quality 2 stroke synthetic is the cleaner burning and fewer deposits. just stay away from "store" brand synthetics.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 10:44am
Good or bad I always used the good stuff in the rice burner and continue to use it in the chain saws, blowers and line trimmers.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 10:47am
Paul - what's the issue with "store" brand synthetics?   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 10:54am
My take on Paul's comment: It does make a difference. I like to know what I'm getting. As to what VFDfireman said, there is some truth in that some claimed synthetics aren't really synthetic. The biggest scam out there, IMO, is "synthetic blend" oils. Test have shown these blends to be as little as 10% synthetic and are little or no better than non-synthetic oils. My problem with store brands is that I don't know what I'm getting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 11:51am
I'm not disputing what you are saying...but there are still more bargain 'synthetics' (rotella, wm,house brands, valvoline, delo, etc. ) that are highly refined conventional than true blue 'synthetics'.. M1, higher end Amsoil, are examples of true synthetics.
I still maintain that the term synthetic is a marketing ploy as the building blocks for the oil still come from the ground in someway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 5:37pm
I currently have 3 different kinds of oil on the shelf. The highest priced stuff is Motorcraft Synthetic Blend, then Mobil Super, then Formula Shell that I got on sale for $1.49 a quart. And they all say "meets or exceeds API service SN" Now if one "REALLY" exceeds this API service, I'd think they wouldn't hesitate to brag about it, but since none of them do, I assume one is no better than the other. They all claim on the bottle to eliminate engine deposits, anti-foam, ect. ect. ect
Edited by Les Royer - 20 May 2015 at 5:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 5:49pm
I've never understood the 'real' reason to use synthetic oil. I can't think of ANY real reason...especially in 60 year old tractors, 5 year old riders, or 2 stroke weedywhackers.
I'd appreciate someone giving a real reason.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 5:49pm
It's really hard to say anything more than what standard the oil meets. If it meets "SN" what more can you say, other than it meets some standard higher than SN. If a higher recognized standard doesn't exist, you can't invent this new standard yourself.
There are other ASTM tests that the oil companies put their products through, but this are Greek to the average buyer so you won't find them listed on the bottle.
If you look through the AMSOIL web pages carefully, you can find the results of other ASTM tests they put their oils through. Occasionally you will find a comparison. The 4-ball wears test (I forget the ASTM number) looks especially good for their 5W-30 oil.
BTW, I looked up "synthetic blend" and found that no synthetic blend motor oil contains more than 30% synthetic. They are using marketing schlock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 5:51pm
Jay
If I had a nice tight engine, regardless of age, I'd use nothing but the best oil in it. It doesn't really cost an arm and a leg to go with the best.
Crewchief View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crewchief Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 7:03pm
synthetic oil runs cooler,cleaner. I 've used only Klotze 4 years..
 I also have several places near me that sells Alch. Free Gas.
It's one of those things ,pay a little more,to help keep u'r equipment running.
1952 B   1950 Ferguson TO-2O
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 7:14pm
I use the alcohol free gas and soy free diesel in my old tractors whenever I can get it.  then I use an extra lubricant in the diesel's fuel for the older injection pumps.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 7:20pm
I've been retired from NYSDOT for about a year now. For the past several years, they have used recycled oil in all engines except new equipment that called for a special oil during the warranty period. When the warranty expired, everything went to recycled oil.
I have NEVER seen an engine failure in any of their equipment that could be attributed to oil, other than engines which the oil pan rusted through and ran low, or empty on oil.
These engines get regular oil changes and maintenance, which I think is much more important than the quality of the oil.
Unless the manufacturer recommends synthetic oil, I personally, think it's a waste of money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 9:00pm
re: ...
Man that does sound 'silly', though I have seen it with my own eyes. Just seems 'wrong' that something oily would rust....
Anyway, I'm reminded of the car guy 'Tom McCahill' of Meccanix Illustrated decades ago doing REAL performance tests including oil changes/no oil changes/filter only and driving the cars several THOUSAND miles.This was all back in the late 50s-early 60s. I recall it was OK to just change oil filter and add a quart,I suppose clean oil is still oily  and the filter traps the 'bad' stuff...
also one of my uncles helped build the Alaskan highway( lost 3 dozers into the permafrost) and THOSE were REAL performance tests , never lost an engine...
 so to me 'synthetic' is just a marketing 'scam' designed to take more of your money from you.
Jay
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 9:10pm
Oil pans rust from the outside in, especially for snow plow/ salt trucks out here in New England.
Edited by Stan R - 20 May 2015 at 9:11pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 9:49pm
Real (and pricey) synthetic can often run more than 4 times the hours/miles in a good engine before gathering too much dirt and ground up bearing inserts compared to conventional oil. The key to keeping it long is to get the oil analyzed at 10K mile intervals and change it when it gets too contaminated. The synthetic I've tried seemed to be thinner but lubricated better by staying in the bearings when the engine was shut down and supposedly made a stronger film in the bearings. In my Golf it wouldn't stay in the engine for the VW approved 10K miles oil change interval, it got two quarts down at 5K miles. Replacing the oil pan helped that but didn't cure it. I went to Motorcraft 5W10 semi synthetic and planned for 5K oil change intervals. Compared to Mobile 0W30 it cost less not counting the filter and the work of making the oil changes. The Golf is gone now, it played Ford 5.4.
Gerald J.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 11:10pm
One of the main benefits of a good synthetic oil is their ability to withstand higher temps with out coking things up (how good is the radiator and how clean are the cooling passages in your old tractor?).
The second is that a dino oil that is rated a 10w-30 will become more like a 10w-20 oil after 50 hours of work.  This won't happen with a good synthetic.
None of the above really applies to a 2 cycle engine, however.  Considering that the only lube a 2 cycle engine's bearings get is what is mixed in the gas, I would get 2 cycle oil from a very reputable supplier.
I personally use Mobil 1 Turbo Diesel 5w-40 oil in everything I have except a newer car that is still on warranty.  That covers everything from my old Simplicity diesel garden tractor to my 2003 Corvette to my 1977 I/O boat to my 15 year old motor home, to my Allis B-10.  I also changed some older used vehicles (1977 IH Scout) over to Mobil 1 oils without any issues.
If you really want to know how good your oil is, send a sample to Blackstone Labs.  For $35 you can find out what's going on in your engine, what the viscosity was, and how much TBN is left (the ability to neutralize combustion acids).
http://www.blackstone-labs.com/standard-analysis.php
Mark
GTH-L Simplicity
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 11:43pm
I use full synthetic and change oil every 20,000 miles. Both my car and van have over 200,000 miles and not use oil or need to be toped off between oil changes.
I also use full synthetic in my lawn mower and weed eater.
I will not go back to conventional oil.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 11:47pm
Engine failure is one thing. Premature engine wear is another. Some people are happy when they get 100K from an engine. I'm not. I traded my Toyota in back in 2001 with 118K miles on it and I thought that was outstanding. When I traded that car it used a quart every 2500 miles. I used Quaker State 10W-40 and Fram filters every 5K miles. With the next car I used AMSOIL 5W-30 and top grade AMSOIL filters. I changed that oil every year if it needed it or not. The car was typically driven 18K miles a year. AMSOIL claims their oil is good for one year or 25K miles. I sold that car to my co-worker when it had 217K miles on it and it now has about 260K miles on it. The new owner continues to use AMSOIL 5W-30 and changes it yearly. The car does not use any oil. Would that car be in the shape it is in if I used a lesser oil? I don't think so.
My new car is a BMW diesel and BMW demands synthetic oil. Most new cars today demand the same. I get free maintenance while the car is in warranty. They use BMW synthetic, which is Castrol Edge Extended Life motor oil and it gets changed every 10K miles. When the car is out of warranty I plan on switching to AMSOIL Low SAPS European grade oil, as AMSOIL recommends.
BTW, WF Owner, how often did they change that re-refined oil? The labor involved with each additional change would probably be almost made up for in savings just by using a high quality oil and doing fewer changes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 12:39am
Fewer oil changes look better and better the older my body gets!!!!  Smile
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 12:47am
i'm thinkin...a Freightliner mechanic told me that the new trucks are running that synthetic, and recommend oil changes at 100,000. miles now.
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 1:07am
Ran wm tech 2000 10w30 in an 18.5 hp non-filter briggs for 11 years, wore out the mower, gave the engine to my brother in law and its still running strong.  1992 olds quad four crate engine on same oil, changing every 5-6K. At 50K, chain guide broke requiring a new head.  You could still see the hone hatch marks in the cylinder walls, never burned a drop.  2010 Toyota Corolla, put it on mobil 5w20 syn at 10K, oil changes every 5K till 60K (end of warranty) change every 10K now, has 142K on it and doesn't burn any so far.  1999 silverado 5.3, been on conventional Quaker State 10w30 since new, I am second owner, now has 248K. oil gets changed about twice a year, little low at change but probably leaks that much.  Other vehicles run Castrol GTX 10w30.
   Spent 5 years in the Army, our trucks were not changed on a schedule, oil samples pulled from engine and trans on a schedule and sent to lab.  Oil changes done based on condition/contamination of oil.
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 1:12am
I don't endorse this at all:
My grandfather owned a 2000 Impala that he bought with 75k miles. He didn't have the money keep safe tires on it, but we were able to do that. He was supposed to have the oil done, but he never did. He went 30,000 miles between changes... twice. That's right- from 120k miles to 180k miles, he had one change done in the middle. That car made it to 217k miles. After he passed, we sold the car to an auto rebuilder who wanted the body and transmission. The head gasket was going bad, there was oil in the coolant, and what came out of the pan looked worse than Elvis Presley's autopsy. I dumped used oil from one of our trucks in there- it at least sort of looked like oil. We drove the car 30 miles to the buyer- 30 miles down the highway. I was puffing white smoke, but the engine still ran.
The point- any engine should make 200k miles if it's taken care of. Heck- that poor 3400 was abused most of it's life- and it still got there. That said, I would keep clean oil and a good filter in a car before I would worry about the brand.
Now, please, don't try to replicate what my grandfather did.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 5:21am
I recently pondered this as the truck I bought had Amsoil in it from day 1 by the PO. Changed to a "regular" oil, cummins approved mainly due to costs. I changed it in the winter. 1st thing I noticed was it did start harder in the cold, fuel mileage dropped 1.3mpg, It also seemed to take longer to feel like it had warmed up and smoothed out. PO changed 1 time a year, with this oil it will be 3 times a year for me. I am most likely going back to it just for those 2 options. I have a local oil guy that sends the samples in for me and all is good. Engine has 103K on it and its a 2003
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 5:45am
I know the oil change interval on large (tandem) dumps is 15,000 miles. I'm not sure what construction equipment and smaller trucks are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 6:40am
I've always used regular motor oil in everything I owned. In the cars, hotrods and the Van, I change the oil every 3000 miles with the filter. My engines were always spotless inside, quiet when they ran and so on. I do use synthetic in JoAnna's Caddy CTS only because it came with it, so I stick to the same oil that is recommended by GM. I change the oil in that every 5000 miles along with the itty bitty oil filter that it has. All the Tractors get the same 10W40 Cam II motor oil as the cars. The Astro van I use 5W30 as recommended, and owned the Van since it was new in 03'. Has about 128K on it or so, never uses oil, and the 4.3L V6 engine is quiet as a mouse. I'll probably continue to run these oils in these vehicles till I get to old to go under the vehicle to change the oil! I know what you mean Mark. It doesn't get any easier as you get older! LOL!
Steve@B&B
