616-620-720 Mower deck shells
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 616-620-720 Mower deck shells
    Posted: 18 Mar 2015 at 12:46pm
There is a gazillion hours to reproducing the deck shells and seems there is no end. Getting close to completing them though.This has been a challenge to keep them as original as possible. I tink I will have 3 to sell if anyone is interested in them. Tracy
Pat SW Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat SW Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 7:01pm
I'm interested...what kinda money you talking about? Thanks, Pat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 10:04pm
Pat, probably around the $1500 mark.They will be very professional.They are thicker than originals on the deck itself. The brackets will be same thickness as originals. It is basically just the deck, no height control on rear. I will post pics when I get them done. Thanks for the interest. Tracy
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 10:59pm
I'd say it would be a challenge to build those decks. Rather time consuming to I would guess.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 9:11am
 You can say that again! They are labor intensive to get to look like originals. Tracy
BrianC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 2:35pm
Just the deck shell and anything welded to it?  So for someone with
a worn through, rusted, bent and re-welded mower, they would swap
the existing parts over to your new shell. That seems like a logical approach.
As for the price, nobody wants to part with hard earned money, but
for a low rate special custom reproduction I think that is fair, in my opinion.
My deck is in good shape however.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 4:12pm
 Brian, that is a great way of explaining them. I would of gladly gave fifthteen hundred dollars for a new deck shell if one could have been bought. I should have two mowing this summer, if all goes well. I have many irons in the fire this year. Thanks for the nice comment. Tracy
Edited by Tracy Martin TN - 20 Mar 2015 at 4:13pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 4:34pm
Tracy,
I've seen your work brother. You're spot on when it comes to your repro's man! They're probably "tits"....  LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 10:29pm
Hi Tracy. What do you use for the rod for the rollers. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2015 at 11:01pm
Mike I use 5/8 dia. shafting(CRS). HTH Tracy
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 3:15pm
what gauge did you go for the new shells?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 4:56pm
I think it was 9 gauge, they are about .023 thicker than originals. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2015 at 8:31am
Ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2015 at 11:00am
We're the originals 10 gauge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 6:03pm
What do ou do with the slides 2172567, there no longer available. My uncle is going to make me some on his lath
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 7:10pm
Mike, I don't have my manual here at home. What part are you referring to?Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 8:15pm
Oh yup it's the 3/4x3/4" square piece that is on a shouldered bolt, goes in the slide for the roller height adjustment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 9:43pm
They would be easy to make. The less lost motion in the roller assembly, the better off you will be. I made all new brackets that hold the axle and bolt to rear deck brackets. Mine were worn bad. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2015 at 10:56pm
Yea they do look easy enough to make. Was just curious how others were fixing it up.thanks
This page was generated in 0.289 seconds.
