water injection
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: water injection
    Posted: 06 Mar 2015 at 9:44pm
If u had to make choice on water injection or air to water intercooler which would be better choice
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 9:51pm
For power, the intercooler. For lower exhaust temps, the water injection. Both will lower temps and give more power, but the intercooler will add a lot of power and lower EGT's a little where the water injection will lower temps a bunch (depending on how much water you use) and add a little power.
Has someone said "take your pick - one or the other"? If not I would use both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 10:24pm
Could do both egts are high was looking to get under control
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2015 at 10:50pm
How high are they?
What is your turbo and pump combination?
What is your injection pump timing set at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2015 at 5:26am
390 head on pump hx35 turbo with 12 cm exhaust housing timing at 33. Thought about trying 14 cm housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2015 at 5:27am
1800
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 7:39pm
If you are happy with its performance just spray a fine mist of water a foot or more ahead the turbo inlet. I would guess 15 ounces in 15 seconds to start with. Nothing fancy or expensive for a pump or nozzle. See what happens if it brings the temps down to 1700 then adjust to 20 ounces. Add water until you get to 1500 - 1600 degrees. That should be a safe number 1300 - 1400 even better. Anything over 20 ounces you may need to inject it after the turbo. Cheapest way to go to get things cooled off. Yes a looser turbine housing may help too, but I would use a little water first and see how it runs before changing any hard parts.
This page was generated in 0.112 seconds.
