D15 question
AdamK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamK Quote  Post ReplyReply Direct Link To This Post Topic: D15 question
    Posted: 17 Feb 2015 at 9:14pm
I want to buy a D15 and it has no serial number. I want to know of it's a series 1 or 2. Is there anything that could tell me other than the muffler, air filter and fenders? Thanks for the help.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:21pm
Headlights are on the fenders of Series II (fenders are the same, but higher up on IIs).  Air cleaner stack is on the RIGHT side of the Series II (series I are on the left).  Aside from these details, they are pretty much the same.
Where are you looking for the serial number?  Left side of torque tube immediately behind the engine?  Might be too pitted there?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:23pm
Check Eng. Serial No. near Carb.
Series II has 160 cu.in. Serial will be 160 XXXXX
Oil filter is 'full flow' like Fram PH 8A
Air filter is Dry Type under R/H Hood.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:23pm
I was looking on the left side on the sheet metal part. As far as the fenders, are they just moved up on the bracket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:26pm
Serial number is NOT on sheet metal.  It is stamped into the casting.  The series II fender brackets are taller, not the fenders.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:27pm
See attached link for Tractor Serial location.
Gary
http://people.clemson.edu/~wsmth/SNLocat/ACSN5.htm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:31pm
AdamK,  The serial number will be located on the Clutch housing on the left side (facing front).  We used to place paper over the number and trace the impression with a pencil.
The serial numbers of the D-15 Series I - 1001 - 8169 (made from 1960 - 1962) The serial numbers for D-15 Series II - 13001 - 25410 (made from 1963 - 1968)
Information from MR SWINFORD'S book Allis Chalmers Farm Equipment 1914 - 1985
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:35pm
Series I fender mounts...
Series II fender mounts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 10:40pm
Okay it looks like they are the series 2 mounts. The guy did tell me it has bigger tires in it so maybe that's why it looks different. One fender doesn't have holes for the lights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 5:26am
Also, on the series 2, the PD handle has a thumb guard on the top front edge...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 7:26am
All D-15's had "full-flow" engine oiling system. Series 1 had oil bath air cleaner (left side stack) and series 2's had a DRY paper air filter (right side stack).
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 7:36am
Dr.
"All D-15's had "full-flow" engine oiling system. Series 1 had oil bath air cleaner (left side stack) and series 2's had a DRY paper air filter (right side stack)."
Don't you mean all D-15 'Series II' have Full Flow Oil Filter.
Gary
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 8:15am
What is a full flow engine oiling system ??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 8:30am
One of the differences between a D-14 and D-15 engine was the full-flow oiling system. They are both G-149 engines, but the D-15 ALWAYS has been full-flow oiling be it a G-149 or a G-160.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 9:09am
BE, CE and W engines have a bypass lube system. Basically what oil doesn't go thru the filter, goes thru the engine. You only filter part of the oil each time it goes thru the pump.
 Full flow is just that. All oil is filtered and then pumped to the engines moving parts.
 That's the best I can describe it. Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 11:56am
Not necessarily.  My 1962 Series I has that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 11:58am
I would guess the latest D-14 models already had the thumb guard and ALL D-15's.
