wet clutch wd 45
bsb45chalm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsb45chalm Quote  Post ReplyReply Direct Link To This Post Topic: wet clutch wd 45
    Posted: 28 Mar 2010 at 6:02am
pressure plate thickness is .165 and other pressure plate is about .200 inches is that to thin ?
I'm putting it back together added 2 new clutch disc's , oher disc is ok thinking that I need to replace other driven disc and  pressure  plates. I would appreciate any in put on this subject!! thank you.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:18am
They will work if all the tractor is doing lite work, But if its going to go back to hard work like plowing I'd do it up right the first time in there. I know that it's more money now but you can burn the new parts out you did put in if it slips too much.
Don
