Tightening the power steering belt on a 160 |
farmtechguy
Joined: 24 Dec 2025 Location: United States Points: 14 |
Topic: Tightening the power steering belt on a 160Posted: 19 Jan 2026 at 4:50pm |
My 160 has very weak power steering. I think I tracked down the likely cause being belt is quite loose. I didn't think to check it while it was cold and it's a lot looser then I realized. Thank you AC720Man for suggesting that. The service manual shows 4 bolts. Two look like they're tucked in the frame rail. I can see why people are saying it's a pain to adjust. Any tips or tricks for tightening? |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5397 |
Posted: 20 Jan 2026 at 8:44pm |
Will have to look at my 160 tomorrow, kinda forgot how I adjusted mine. I installed a new belt and adjusted. It has to be the exact length belt as there isn’t much adjustment on it. I do remember that. Seams like I used a slight angled pry bar to hold the tension while I tightened the bolts.
Edited by AC720Man - 20 Jan 2026 at 8:46pm |
AC720Man
Posted: 2 hours 14 minutes ago at 9:25pm |
I forgot about this post so I apologize. There is one bolt that you loosen that the PS pump slides on. I used a small pry bar between the front crank and the PS pump to get the belt tension correct and then tightened the tension bolt.
