Three year old Ford Expedition |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35055 |
Topic: Three year old Ford ExpeditionPosted: 09 Jan 2026 at 6:48am |
Good friend of ours and I were speaking last night as mentioned blower motor, he noted replaced there old Expedition with a newer one a little over year and half ago. Got thru a close by dealer and was one of the Ford Certified used cars, 1 year warranty as bought. The wife was driving it and all the Aux functions quit, radio, windows, dis have wipers on and working but would not shut off. So to a repair shop as no warranty remaining.
Came to find out the electrical system is split into TWO Separate bodies, engine/drivetrain and what can be considered Accesoiries, has TWO Batteries, Separated Charging Circuits thru a special Module where charges each battery separately, accessory battery was not accepting a recharge where was getting a charge value, replaced battery and all was good again for two weeks. Repeated. So replaced module ar Ford, again not warranty, $488, as well new battery was drained and would not recover so took back to first shop that replaced NC. So far seems good and been a couple months. He is now gunshy of it. Been explained are SEVENTEEN separate modules in their car. Charging Module one of the least expensive and known failure point. |
DMiller
Posted: 09 Jan 2026 at 8:30am |
Related same to guy I received KW from, he has a newer Jeep, Same, TWO Batteries and independent charge system, his New F550 Diesel THREE Batteries and closer to THIRTY Modules, he is going to trade out ANNUALLY to Semi Annually to keep Warranty and functions as see this even in OTR Semi Trucks.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1548 |
Posted: 22 hours 2 minutes ago at 8:39am |
Crazy. Hard to understand why these manufacturers want to make things so complex. No need for two batteries in a vehicle like that.
DougG
Thanks(1)
Posted: 20 hours 12 minutes ago at 10:29am |
Its gotten Fricken nuts,,,, Ive never believed in buying new,, but if it keeps it under warranty- and they stand behind it, probably how Ill go,,,
DMiller
Posted: 19 hours 42 minutes ago at 10:59am |
Two batteries takes Parasite load off the Start System battery and keeps it off the machine to be able to drive after short but longer than normal parked durations was what I was told. The Onboard Control Modules for all the Enter/Info-tainment systems up links and reloads all the time, unless add a battery isolator and reprogram every return to power or add a plugin battery charger to be plugged in for longer durations it is what it is.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24936 |
Posted: 18 hours 47 minutes ago at 11:54am |
gee every EV has TWO batteries......THAT is like, um, totally STUPID !!! Wife's NISSAN 'only' has 8 computers.. the remote start one crapped out, so car could be driven without the key . NISSAN 'experts' couldn't find the problem after 3 tows to 'best dealership in Hamilton, wall of diplomas of the 'factory trained and certified' techs...... ...in the end I READ some NISSAN papers, and my $5 homebuilt 'scanner' SAW the problem module. Idiots...... |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5213 |
Posted: 10 hours 41 minutes ago at 8:00pm |
And there are many here that make fun of me driving my pre computer vehicles and I should join the modern world. NO WAY. everything I own is paid for and can be diagnosed the old school way: Past knowledge and experience. 99% of issues can be fixed on the side of the road with simple tools enough to get home, and with common preventive maintenance even that is rarely an issue to be concerned about. My FULLY mechanical diesels with manual transmissions, if they can roll, be pushed or towed enough to turn over will run with no electric whatsoever.
With the high rate of sensor failures I hear about does everyone carry a full complement of sensors in all of their vehicles?
