The One-Ninety XT Story for new members
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 8:44am
2 3/4" for the small (same as D19) and 3 1/4" for large (same as 200-7000-D21)
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 11:45am
Thanks for the education, this has been an interesting thread to read so far.
Galatians 5:22-24
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 12:21pm
Cut my teeth with a 65 190XT ... very few problems .. traded it for a 986 .. wish i had it back .. It was traded in in 1980 at Howery Imp .in Darlington  Wi. maybe a forum person now owns it ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 1:12pm
I just bought a straight one ninety with the 265 gas engine and the small axles. It hadn't run for a few years and had a push rod out of position. It runs good now except
that I can hear valves hanging up and poping at an idle. Is there an oil additive that can cure this or do I need new valve springs?
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 1:20pm
Add a quart of Rislone and run it/work it. Should clean things up.
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:11am
okay what is that measurement ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:12am
sorry wrong placen  for my question. Tman
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:14am
ANy body find those diameters mine is 3.25 inches, and hoping it is the bigger one.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 12:05pm
Rislone might work.  Another way is to change the oil to a high detergent oil.  Most diesel oils have more detergent in them, and synthetic oils have even more.  If it were my engine, I would put Mobil 1 5w-40 turbo diesel oil in it.  That oil is also rated for spark engine use.  And then put a load on it for a while.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 12:53pm
The one I bought is a 65gas XT with a 301 that is dated 64. It has the 2 and 3/4 axles. Something that is neat is the lever behind the tractor under the tank that you put a jack handle in to raise and lower the 3PT. I heard the newer ones didn't have it. Someone thought it was probably unsafe. There is a bungee cord tied to the sea After I got the slop out of shifter linkage it feels tight and I can't get it to pop out of 1 through 3 but 4 you can push the shifter quite a bit further from were the detent is. Isn't there a fix for this like redrilling detent hole?
