Sun shade for D14
shoemada View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shoemada Quote  Post ReplyReply Direct Link To This Post Topic: Sun shade for D14
    Posted: 07 Jun 2025 at 5:48pm
I have a narrow front D14 that I mounted a small spray tank on the back. I intend to use it for spraying ditches this summer since it will go through taller corn than my atv.
I’d like to mount either a “buggy” style shade or umbrella. The 30” fender width seem too narrow for the 40” buggy style I’ve seen.
For those of you that have such a setup, how did you mount the frame of either style? Pics would be great if that is possible. Thanks in advance for the help
Don
shoemada@yahoo.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2025 at 6:33pm
I have had a 40" buggy style sunshade on my D15 and it fit nicely. I currently now have it on a D10. If you get the shorter "fender" mounts instead of the "axle" mounts you can swivel  the attachment point out to the needed width.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2025 at 8:44pm
https://tractorumbrellas.com/products/allis-chalmers-ac-buggy
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 7:52am
Narrow front and ditches are a dangerous roll-over mix!
Be careful out there.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 7:59am
I've run narrow fronts for years,all my life really and don't find them anymore dangerous than wide fronts,a lot depends on the tractor.An AC B with a wide front is way more unstable than a NF CA.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2025 at 7:08am
I have an umbrella on my d14 mounted slightly behind the seat using all factory holes.  I will try to remember to get a picture for you.
I agree with Gary, narrow fronts aren't anymore dangerous than wide fronts.   That said there are places I will go with a wide front that I won't with a narrow front, but some of that depends on what tractor I am using and knowing the limits of the narrow front.
