Snap coupler snowblower |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Topic: Snap coupler snowblowerPosted: 20 Dec 2016 at 4:31pm |
Was daydreaming a little this last weekend. Is there such a thing? Never heard of one.....I am sure I could make brackets to mount one, but I have never used a tractor mounted one so I don't know if it would even work? How much HP does it take to run a 6 footer? 8 footer?
I just hate to see the old WD sitting around hibernating when I could be working with it... |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 20 Dec 2016 at 4:45pm |
ANY 'behindyour butt' snowblower ,is, well , a PAIN in the butt ! Yes they work well BUTT you're always going backwards, body turned in ways it was NOT designed to do....I've even given up using the Oxnard rear blade to push snow,It's a LOT easier to sit on my butt on a garden tractor setup with front mounted snowblower. I have one unit permanently setup as the 'snowblowing' machine.
However, if you do want a 'project' and can get a 6' blower,figure out how to 'reverse' the steering and levers and pedals so that going backaward is forward( aka forklift mode). Even if you just mount the blower on 'regular', be sure to swap the rear tires, you'll get more traction(member going backwards is going forward...). Obviously some kind of cab is ,well, needed, unless you like cold snow going where it don't belong ! I have seen 'used/abused/needswork' 6' blowers up here for 350-450 Canucks but I can't justify one. Jay |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2685 |
Posted: 20 Dec 2016 at 5:08pm |
I have a single stage snap coupler blower. Makes a good rear weight!!!!!!!!!!! Give you a great deal on it.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 20 Dec 2016 at 5:21pm |
Norm's book has a picture of one. I believe it was part silage blower. It never went into production.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54738 |
Posted: 20 Dec 2016 at 5:58pm |
Yeah, but if someone finds the prototype, it would be worth a fortune...
dawntreader74
Posted: 20 Dec 2016 at 7:03pm |
put a old wd loader on an a pickup snow blade on wear the bucket was works good' piles it up to' also good for loading things in the summer time.
mdm1
Posted: 20 Dec 2016 at 7:19pm |
I believe Arps made one for Allis. It could be fitted with a snap coupler or 3pt. Mine is one that has been converted to snap coupler. I believe I have a manual somewhere.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 20 Dec 2016 at 8:19pm |
I spose you have that up Norte Mike? I'd like to see that. Seems to me, I think you had some pics on here a few years ago?
I agree though, I'd rather have something out in front.... |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3295 |
Posted: 20 Dec 2016 at 8:20pm |
Anybody got pics of one. I have been thinking about buying or building a single stage pull type blower.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 20 Dec 2016 at 8:45pm |
I don't think a pull type would work very good if you have to ram/jab a drift!
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 20 Dec 2016 at 8:53pm |
We have one here that we use, I will have to get pictures of it.
mdm1
Posted: 21 Dec 2016 at 6:08am |
Do a search for Arps single stage snowblower. I thought about putting a slick finish on the chute and inside like I am going to put on the bottom of my boat. But I do have a truck blade that I mount on the loader.
Dakota Dave
Posted: 21 Dec 2016 at 8:54am |
I have a snap coupler blower don't know who made it in my tree row under several feet of snow. I also have an erskine v type rotary plow pulls behind the WD 45 works great picture of pull blower below. for keeping the road clean blows the snow way out in the trees. If you can drive through it you can blow it. When the drifts get over 3' you can't drive through it any more. Even with wheel wieghts and tire chains. Right now I n
Have a 7 ft IH back up blower on my WD45, the back up blower works great for opening up impassable drifts and blowing back the road edges. All the wieght is on the back tires with chains on just keep backing till you can't move any more lift the blower and drive out. I had a front mount but as soon as you couldn't move foward any more you just got out and get the wife to pull your stuck tractor out.
Edited by Dakota Dave - 21 Dec 2016 at 9:06am |
cpg
Posted: 21 Dec 2016 at 9:18am |
uploads/14031/WD_blower_Medium.jpg
To make it easier to find a blower it is not hard to put a basic 3 point on a WD. I just have the arms bolted to my hitch mounts and connect the top link to lift arm bar. Not perfect but works pretty good. Just have to chain the lift arms to the hitch so when the blower is down they are tight so it doesn't flop side to side. I have a 7 foot blower right now which is too much. Lots of time on the hand clutch feeding it into the bank and when you pick it up you pretty much steer with brakes! I am trading my dad for a 6 foot since he has the big farm tractors to run the 7 footer and that is a nice size. We always used the 6 foot on the farm with the old family WD that is there. It is a nice size and nice to have the 3 point for any other implement you come across and want to use! |
Lonn
Posted: 21 Dec 2016 at 9:30am |
Edited by Lonn - 21 Dec 2016 at 9:32am |
Wink I am a Russian Bot |
DiyDave
Posted: 21 Dec 2016 at 5:29pm |
The one in this pic looks a lot like an ARPS. You can reverse the frame and blower, and turn it around 180º to make it a rear facing back up type plow. These need a good coat of paint,and some veg oil, to keep dry snow from sticking. in wet stuff they are practically useless...
Dakota Dave
Posted: 21 Dec 2016 at 7:56pm |
Nope its an Erskine Champion rotary plow made in Erskine Mn about 50 miles from here. still has the manufactors tag on it. its a 6' with a right extension wing. its on a 3 point adapter and not reversable. I dont have any better pictures of it and currently have a IH model 70 two stage blower on my other WD 45 this one just has the snow bucket. Having the bucket and loader on the same tractor is very unhandy.
