Sleeve orings on 190
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Sleeve orings on 190
    Posted: 20 Mar 2017 at 11:17pm
In my IT manual is says to coat sleeve orings with light motor oil and install quickly. I see there is a lot of controversy using petroleum products, just wondering if oil is OK or what you folks are using.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 12:22am
I use vegetable oil, if you use motor oil you have to very quick before they start expanding.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 6:50am
The only time I ever installed orings, I used John Deere oring lubricant. That's some very slippery stuff
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2017 at 8:11am
Dish soap works good too but you gotta flush the block or you'll think something's wrong when your engine starts foaming at the mouth
Wink
I am a Russian Bot
