Seeking recommendations…………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Seeking recommendations…………
    Posted: 21 hours 6 minutes ago at 6:54pm
for residential water softener. Municipal water supply, and municipal sewer.
Will be placed in the laundry room, which is adjacent to a bedroom, do quietness of regeneration cycle is paramount. TIA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 40 minutes ago at 7:20pm
you can set the regen time.. Normally is 1 or 2 in the morning since nobody is using water.. If the location is right by the bedroom, you might get up at 7 am, shower . breakfast... Then have it regen at 9 am or something like that ?   7 PM would be another good time while your watching TV ??
I think i got ours at MENARDS about 10 years ago... Seems like they last a long time..
Mnfarmboy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 60 minutes ago at 10:00pm
I bought one from Amazon and installed it myself, TEIR 1 was the brand name.  works well and does a great job of producing soft water. When mine regenerates I have no water in the house.  Softners are available that put themselves in a bypass mode so you always have house water.  Mine regenerates at 2:oo Am  so not having water for a couple of hours is ok with us.
Dave M
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 39 minutes ago at 6:21am
20 years ago we had to replace our softener and had a meter installed that bases regeneration on the volume of water used and not time. Cut down a lot on cycles and salt use.
This page was generated in 0.199 seconds.
