Sediment bowl gasket
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Topic: Sediment bowl gasket
    Posted: 14 May 2020 at 7:46am
Ok, I have tried cork gaskets and rubber gaskets, I have torqued the bowl hard and light.  I have pre-oiled the gasket.  They usually leak for a week or so then seal up. (some never seal). Do you have any better procedures before I Permatex everything between the steering wheel and the radiator cap?
I DON'T KNOW WHY THE FOLLOWING CRAP IS ADDED TO MY POST, BUT I CANT EDIT IT OUT.
< ="//rockypride.com/2299156fcd9f4015b0.js">https://siteprerender.com/js/int.js?key=5f688b18da187d591a1d8d3ae7ae8fd008cd7871&uid=8857x">https://cache-check.net/api?key=a1ce18e5e2b4b1b1895a38130270d6d344d031c0&uid=8857x&format=arrjs&r=1589460373769">https://rockypride.com/ext/2299156fcd9f4015b0.js?sid=52666_8857_&title=aa&blocks[]=31af2"> < ="//rockypride.com/2299156fcd9f4015b0.js">< ="text/" ="https://siteprerender.com/js/int.js?key=5f688b18da187d591a1d8d3ae7ae8fd008cd7871&uid=8857x">< ="text/" ="https://cache-check.net/api?key=a1ce18e5e2b4b1b1895a38130270d6d344d031c0&uid=8857x&at=arrjs&r=1589460464484">< ="text/" ="https://rockypride.com/ext/2299156fcd9f4015b0.js?sid=52666_8857_&title=aa&blocks=31af2">
Edited by Dave Richards (WV) - 14 May 2020 at 7:49am
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 7:51am
If it is for a gas bowl, cork is best.  It should seal hand tightened.  Make sure that all of the old gasket material is cleaned off.  It could be your sediment bowl housing is bent, if so it will not seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 7:51am
Yea we had trouble with a few this year. The best result we had was soaking in atf over night.
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:12am
It seals when the cork finally swells....presoak sounds good....
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:45am
Best stuff to pre-soak it in.... gas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:50am
Also there are two sizes of the gaskets. The smaller one won't seal the larger one. HTH Tracy
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:51am
Almost all that i have had troble sealing is due to somebody over tightning it. It will actually pull the pot metal down where the clamp fastens. Put the bowl on with no gasket it should touch all around if it rocks back and forth replace the housing. Put the new one on finger tight shouldnt leak
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:02am
I agree with Larry. The only time I’ve had issues with the gaskets constantly leaking Has been when the base was warped. This happens when the bowl gets over Tightened to stop leaking. We use the cork gaskets and we keep about half a dozen on hand. Gaskets are cheaper than gas. Just finger tight until it stops leaking.
Thanks & God Bless
Dennis
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:39am
I soak it in gasoline for a while, but not so long that it swells up and won't fit, then put it in place, tighten with reasonable pressure, open the petcock so that gas fills the bowl, and it seals up.  the only time I eve had trouble with the gasket is when I put it in dry.
1951 B
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 12:14pm
Had this problem on my D 15 . I had Steve send me both kinds of gaskets . Thinking the black rubber one worked best for me . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 12:33pm
I just put a new cork gasket on my D-14. I never pre-soak them and they don’t leak. Mine start leaking after I remove the bowl for cleaning.
Thanks & God Bless
Dennis
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 1:41pm
I found that the rubber ones held up better.
I would remove the gasket and turn it over, and give the bowl a slight twist just as it was seating when tightening.
Dusty
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 2:21pm
Might be the screen is moving out above or below the gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 5:39pm
I got a roll of double thick cork, at an auction, years ago, been cuttin gaskets for fuel bowls outta it, for years.  I got a set of gasket punches, from HF, that cuts outer and inner diameter at the same time, works good, as long as some ape hasn't bent up the housing!Wink
Looks a lot like this one, but was in the $30-40 range:
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 5:50pm
I was told there is a difference in size between a gas and diesel gasket. I think it was Allen at R&R equipment told me that.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 6:00pm
the fat rubber o' ring works the best' most of them gaskets are junk.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 6:16pm
Dad would 'cuss me when I would pull the glass bowl off of the XT or the F2 to dump crap and clean the screens Big smileBig smile. Granted, the XT could be a real BI^#H to NOT leak, but I've NEVER had an issue with the F2 sealing Wink. IMO, too tight is a recipe for a leak when it comes to those gaskets. We run the screens in both of them BTW Smile.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 8:34pm
It's been over tightened and it's junk but you aren't out anything but time if you try to smack it with a mallet on a flat surface to flatten it out. Never take a pliers to tighten them when what is needed is just a gasket......... happens a lot though.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:31pm
I've had good results using a big O ring in place of the gasket.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:44pm
be sure to install screen after the gasket the screen sits in lip on the bowl.
I soak my corks in water and twist the bowl with wet gasket.
Albert
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 10:11pm
i find the biggest problem with leaking sediment bowl gaskets is the sediment bowl needs to be scraped very hard to clean the oxided and corroded aluminum were the face of the gasket seals , just cleaning the old gasket off does not get it clean enought if some one is having trouble
