Secret to getting belt on
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Secret to getting belt on
    Posted: 30 Mar 2018 at 4:05pm
I'm replacing a correct 5/8 inch belt on my C, but having cussing fit trying to get the belt onto the crank pulley.  What's the secret?  It's tight!!
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 4:55pm
Tight as in too short?  Or won't fit in a space?  I can't remember how the belt goes on a C.  The generator bracket and fan pulley may need loosened up a bunch.  I'd get the bottom on first, then fight it in a spot where I can work.
AaronSEIA
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 5:25pm
Did you loosten the adjusters and open up the waterpump pulley. That's were the belt length adjustment is.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 5:33pm
Best way or the easiest way? Probly the easiest way is to take a blunt screwdriver and beat it on the right side then the same on the left side. That's before I said the heck with it I aint gots time to pull the front pedestal back to where it has a wider gap.
Edited by Dick L - 30 Mar 2018 at 5:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 5:41pm
One of my C's I pulled the pedestal off and took the angle grinder to make a wide enough space to push the belt thru. I decided the belt being rubber it would out last me even if I drove it in. After it was on I could not see any damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 5:50pm
SHHH, my secret fer difficult belts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 5:50pm
However you do it, it's a heckuva lot EASIER than changing the belt on my A-C forklift !!!! Only (!) took 1/2 day..needed a motorcycle lift as well !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 7:08pm
I pulled the hood, grill, radiator, and pushed and pulled and got it on.  IT WAS TOO SHORT!  Had to pull it off!! Dang--it was harder to get off than on!  Went back to NAPA and got the right one.  Sheeeesh.  I should have just used a 1/2 inch belt instead of the 5/8ths.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2018 at 7:42pm
The good thing is with a new belt you will never have to do it again with that C. Of course there is always more C's out there for you to tackle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2018 at 1:52pm
When it's too tight, it's the wrong belt....ALWAYS...
That is, if everything is loose when you go to put it on.
Yup, a LOT more C's out there to fix....
sauto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sauto Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2018 at 7:26pm
Harbor freight stocks those belts......... do not remember price but very reasonable as I recall  .............  used it o
n my wd45
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 7:34am
How well do those belts hold up? Do they stretch after a little use?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote sauto Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2018 at 8:31am
Haven 't had a problem with that.............. but if it did stretch a bit you could take a notch out........... I'm going to use it on my ford industrial 4000 when it s belt needs replacing... makes a guys life a little more simple !!!   :-))  ...........
This page was generated in 0.313 seconds.
