saved from the scrapper
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Topic: saved from the scrapper
    Posted: 05 May 2012 at 12:24pm
Brought this plow home from the scrapper, looked way too good to be melted down!  It's a 2000 semi mount 5 bottom, it's sat outside for awhile but it's pretty well all there - rolling cutters, cover boards, even had the factory hitch pins tied to it. :)  Got the wheel bearing fixed and found an old cylinder layin around.  gotta get a new hydraulic hose n it'll b ready for plowin!  we have a 4 & 6 bottom 2000 so this oughtta feel right at home.   should i taek a wire brush to the bottoms for the rust?
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 1:28pm
I would not waste time with the wire brush if you have some sandy or abrasive soil to scour them. My personal opinion
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 1:42pm
I used an electric disc sander on my 53 when I got it. Just lightly go over each moldboard a little at a time and eventually the disc will be built up with enough gunk it'll polish more than grind. Then I went out and plowed 10 acres of sandy clay hills and clean the moldboards off at the end every time I picked the plow up. Kept it coated with plow coat or slip plate ever since and it's always ready to go.Big smile
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 2:04pm
paint the moldboards with ATF and let set for a couple of weeks and with in 30 min of plowing thay will be shiny.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 2:08pm
Nice find around here any 4 bottom and up has been selling for $500.00 and up there is alot of CRP ground comming out this fall i think thats what people are wanting them for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 2:42pm
thanks for the tips, what is ATF?  Jerry
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 2:48pm
Auto transmission fluid. Nice plow! Really bothers me to see some people send something like that for scrap! I know people get desperate for money, but sell it to someone who will use it. I saved an IH 550 from scrappers last fall, and used it for recreational tillage!
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 7:49pm
That's a very good looking plow.  Thanks for saving it!!!
Matt Folkers
FOLKERS RESTORATION
allis4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis4ever Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 8:08pm
any interest in parting with that add a bottom it has??  Love to turn my 6-18 into a 7-18  Assuming it has  the 18" bottoms.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 8:21pm
that would sure go nice behind my 190XT.  great find
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 9:46pm
very nice plow Floyd. check around for the availibility of replacement plow shares in case you break the tip off one. i've had a devil of a time getting anything for my 60 series plow. would bet your plow will really turn over any residue without pluggin up.
