Rod bearing question
 Post Reply Post Reply Page  <1 345
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2022 at 12:10pm
While I'm this far into it I am probably going to check the steering pump out and oil and water pump (any tips for these things?) I plan on just going by the manual and checking things out to make sure they aren't worn out. While I had it running a couple months ago it did seem to have a whining sound in the motor at the front which I'm guessing is the hydraulic pump so I'll probably look at that too...
Thanks Matt
Edited by Hunt4Allis - 19 Apr 2022 at 12:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2022 at 5:18pm
I have used strips of old blue jeans or even a multi folded paper towel wrapped and taped around journals. Duct tape lives longer than masking tape.
Am I able to just flush the hole out before I roll the new bearings in with some spray? (Wd40 type spray)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 7:55am
In other words I'm asking whether the oil gallery runs horizontal through the crankshaft or is it just a hole that's bored perpendicular to the bearing surfaces? I can't tell by my shop manual...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 8:44am
you should be able to BLOW out the ports with air... if the BEARINGS have not been installed on the mains/ rods .......... there can be DEAD ENDS if a bearing is in place.
