Return to Cartridge style filters
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Return to Cartridge style filters
    Posted: 30 Jul 2021 at 7:24pm
Been looking at newer machines and vehicles, to address waste levels the manufacturers are returning to Cartridge style filters with reusable housings and end caps.  That includes Fuel, Oil and Hydraulic filters.  Are now a few upstart companies with Canister kits to convert BACK to Cartridges from spin on filters.
What was old and obsolete is New Again!!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:25pm
A bunch of total idiots. I converted my Oliver tractor to a spin on oil filter after fighting with it for many years.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:48pm
I have a Ferguson that has the canister and it's a PITA. Need to do the conversion on it to the spin on filter.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:56pm
At the factory i worked, most of equip had canister filters... I CHIT canned them all and bought aftermarket spin on filters / new head assembly and piping.. Specked it all out for flow and micron rating.... Canisters always leaked at fittings / o-rings.... of course they were 50 years old also !
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 11:40am
We have a 16 RAV4.  It has the cartridge filter.  You need a special wrench to get the canister off.  After I discovered that, I ordered the tool and also a metal canister.  The original was plastic.  The new filter comes with a new O ring and a drain device.  You take the nut out of the bottom of the filter and screw in this drain,  It drains the oil outta the filter before you take it off.  I was a little upset when I first discovered it, but once I knew, it's a great setup.
My friends shop has a wood burner.  It takes care of them lot's better than the can filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 12:57pm
YEA... you should try doing 25 of them after they are 50 years old !!  Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 1:00pm
My 2013 Dodge Dart has the canister oil filter- WHY ??? Thats gonna be aggrivating
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 1:10pm
Wink That should make a greener cleaner world. LOL You know how many people get the oil changed a Jerko................ Jiffy Lube(or what ever they go by in your town) and they end up cross threading/stripping the oil plug. I can see them putting a new o ring on the lid of the canaster and not have 1/2 of them leaking.LOL
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 8:37pm
What goes around comes around. Lol. I’m going around this cycle for the 2nd time now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2021 at 8:52pm
The new designs are much better than the ones we dealt with years ago. Pretty good to deal with and zero leakage. šŸ˜€
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 4:58am
Not all are leak free, several of the Heavy machines I operate are late model with canister filters and most are ooze messes.  Change orings or seal gaskets an still ooze, a few canisters also been changed with no change to oozing.
This page was generated in 0.131 seconds.
