Rescuing an Allis B That Should Be Parts |
BryceBurden
Joined: 12 Feb 2025 Location: Shattuck OK Points: 19 |
Topic: Rescuing an Allis B That Should Be PartsPosted: 13 hours 5 minutes ago at 2:52pm |
Hey everyone,
I figured it was time to start a proper build thread on this little Allis B I dragged home recently. I picked it up in an online auction last week, and to be totally honest… it’s probably the saddest tractor I’ve ever loaded on a trailer. Most folks would have called it a parts tractor or yard art, and I wouldn’t have blamed them. But Bs are getting hard to find in my area, and when you do find one, it’s usually in about the same shape for three times the money. I’ve been told more than once that I’m crazy for trying to save this one – which usually means I’m on the right track. My plan is to do a full teardown and rebuild, one subassembly at a time. The engine will probably be the last thing that gets rebuilt. First comes dismantling, transmission, final drives, steering gear, and so on. I’m documenting the whole process, and I’ll post updates here as I make progress. I’m always open to advice, tips, or warnings from folks who’ve been into these Bs before. Here are a few photos from the day I brought it home: ![]() ![]() ![]() ![]() For anyone interested in following along, I’m also making a video series on the rebuild. Here’s the first part of the project: Appreciate any input from the Allis folks here, and I’m looking forward to sharing the journey as this little B slowly comes back to life. — Bryce Allis B Rebuild Part 1 Edited by BryceBurden - 13 hours 3 minutes ago at 2:54pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3976 |
Posted: 13 hours 2 minutes ago at 2:55pm |
looks alot better than some of the stuff ive started with
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54540 |
Posted: 12 hours 34 minutes ago at 3:23pm |
Roger Welsch is smiling down on you!
Joined: 11 Sep 2009 Location: illinois Points: 88886 |
Posted: 11 hours 41 minutes ago at 4:16pm |
no battery... no boss mount for generator on engine ... front rims rivet to the hub.... your right.. its an early one... Serial number is on the trans casting by the shift lever... Motor casting "11" should be the second year of manufacturing i thinkg.. started with "10" ?? Might be an engine serial number on left side of engine casting by bell housing..
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 307 |
Posted: 11 hours 19 minutes ago at 4:38pm |
Hi, what is the reason for the chain under the bell housing?
If you were closer, I have an engine with no freeze cracks id let go cheap |
'41 Allis B
'45 Allis B '49 Farmall Cub '72 IH Cub |
BryceBurden
Posted: 10 hours 5 minutes ago at 5:52pm |
From what I can tell so far the front half going off the 11 casting code is a 39. The transmission and final drives are later, serial number shows to be a 48. In the video I stated the rear half was a 47, but that was before I realized that the serial number records on this site showed the last number for that year rather than the first.
BryceBurden
Posted: 10 hours 2 minutes ago at 5:55pm |
The chain under the bell housing is what is holding up the stay rod for the axle. The casting is broken off where it would normally attach to. Not sure how I’m going to fix that yet, have a lead I’m going to check out soon on a parts tractor with what I hope is a good block, but the torque tube has been broken in half on that one so that won’t do me any good in that department
jvin248
Posted: 6 hours 18 minutes ago at 9:39pm |
"Who needs four wheels?" With the work you plan, I'd seriously consider configuring that tractor as a Low Rider. Front axle inverts and rear bull gears are rotated. Then slap a belly mower under it. With a snow blade for winter adding chains and weights. There are a few YouTube videos of B "repowers" using the Harbor freight Predator 16 or 24 HP motors. That might be a fun diversion until you find the motor replacement/parts. . |
