REPLACING CAB FLOOR
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: REPLACING CAB FLOOR
    Posted: 04 Jun 2010 at 9:07pm
 HELLO
     I AM LOOKING AT A BLACK BELLY 7060, THE FLOOR IS BAD, DIDN'T GET TO PULL THE FLOOR MAT UP COMPLETELY JUST PULLED IT UP AT THE DOOR.  THE BOTTOM OF THE CAB AT THE DOOR IS RUSTED OUT. THERE IS A BAD SPOT AT THE END OF THE FENDER BY THE DOOR BACKWARDS FOR ABOUT  6" IS BAD. THE FRAME WORK UNDER THE FLOOR MAY BE BAD. HAS ANYONE CHANGED THE FRAME WORK OUT? IF SO DOES THE CAB NEED TO BE LIFTED TO CHANGE IT OUT.
     THE REPAIR TO THE CAB BOTTOM, HAS ANY ONE DONE IT? IF SO HOW MUCH TROUBLE AM I LOOKING AT? ANY TIPS.   THANKS FOR THE HELP
This page was generated in 0.073 seconds.
