Rebuilt 426 with a weird noise.
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: Rebuilt 426 with a weird noise.
    Posted: 11 Apr 2019 at 6:01pm
Got my 7060 back together after rebuilding the engine, runs good, oil pressure is at 25 psi at idle, after a couple of hours of hard hard chisel plowing running John Deere break in oil, no blue smoke, starts better since I advanced the pump to 19 degrees, no noticeable blow by, but I'm hearing a whooshing sound or like air escaping somewhere when running at high RPM, primarily with the cab door and windows shut, doesn't seem to really lack power while pulling a 9 shank, remanufactured injectors, brand new turbo, all my connections look tight going from the air filter to the turbo, new intercooler boot, all new intercooler gaskets etc. Just an aggravating whooshing sound, any thoughts?
oldways View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldways Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 6:04pm
Air in hydraulic a system ?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 6:38pm
Intercooler gasket problem??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 7:17pm
That's kinda what I'm leaning towards, but it is new and it seemed to go on right
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 7:19pm
seems more like it's coming from the engine
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 9:30pm
Have saw them blow at back of intercooler. Have been using some gasket sealer on them.               MACK
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 9:33pm
Even if you think the rubber hose on the cross over seems tight check it. We had one come loose and make the noise you are describing.
ryan
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 5:02pm
Pressurize the air to air and as much of the hosing as you can. About 20 psi. You will find the leak if there is one. Sure sounds like it.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 8:18am
Know a guy that had a JD engine rebuilt at the dealer. Had great power but had a noise under load. Took a while but we found the intake wasn't completely tight. Had to put shorter bolts in in a couple of places
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 10:15am
Where would be a good place to hook into it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 10:30am
There are only so many places it can be leaking. The turbo hose to crossover pipe. The crossover pipe gasket to the intercooler. The 4-bolt cover on top of the intercooler. The intercooler to cylinder head gasket. That's it.  This of course assumes all the plugs ( four) are in the intercooler body.  This also assumes you don't have an exhaust leak, which you should see the soot from.  It would take me less than an hour to drain the coolant in a clean 5 gallon pail and remove all the intercooler bolts and see what is going on. I always glue (3M brand 8001 yellow) the intercooler gasket to the intercooler and a thin layer of any RTV from the gasket to the cylinder head and recheck the bolt torque (engine COLD) after it has run a couple of days.  You did glue the intercooler gasket to something, right ??
Edited by DrAllis - 14 Apr 2019 at 10:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 10:52am
You could hook up some air pressure to the ether port,but with open valves, I don't think that it will tell you much. The intercooler to the head gasket is most likely the problem if it is an intake leak.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 11:15am
It's a lot of work, but to pressure check the intake tract, you can take the rocker assembly off, and put a plate in place of the crossover tube. My bet is either blown intake gasket, or a small plug left out on intake somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 1:29pm
I did use a bit of super glue on the gasket to mate it to the intercooler so it would stay in place while I installed, no rtv though. All I can see is 3 plugs right in front, 2 small and one big one.
