RC vs WC ring anf pinion differences
Jomo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jomo Quote  Post ReplyReply Direct Link To This Post Topic: RC vs WC ring anf pinion differences
    Posted: 11 hours 5 minutes ago at 2:54pm
Just bought an RC and it's missing it's ring and pinion assembly, is it possible to put an WC ring and pinion into an RC casting or should I try to source and RC one or a complete WC rear end? Are the carriers the same length to go into the case. Would mainly be using for pulling wagons, raking and parades mainly not really planning on plowing with it.
Edited by Jomo - 2 hours 51 minutes ago at 11:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 56 minutes ago at 11:03pm
Ring and pinion ratios are 6.6 to 1 for an RC (and a factory WC high-crop) and 4.7 to 1 for a regular WC.  There is almost a 30% difference in gear ratios slowing down the RC. Both tractors were made to plow with a 2-bottom plow in second gear in normal conditions. The RC had a faster engine speed of 1500 rated RPM while the WC was at 1300 RPM. So, there is 15% picked back up in faster engine speed for the RC.  If you're going to use it as a parade tractor, WC gears would suit me just fine. If you plan on plowing with it and use WC gearing, you will be in LOW gear to plow.
