R50/R52 Rotor drive torque hub |
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 113 |
Topic: R50/R52 Rotor drive torque hubPosted: 18 hours 11 minutes ago at 9:34pm |
Is it possible to repair/rebuild the torque sensing hub on rotor drive sheave? Pretty confident i'm starting to have some issues with mine on my early R52. When running wheat i plugged the rotor but the engine never slowed down so i didn't realize what was happening until i burnt the belt off. Anytime i've plugged the rotor in the past it would pull the engine down and stall it unless i hit the separator switch. Put on a new belt and finished wheat but plugged it a few more times without pulling the engine down, would maintain cylinder speed fine until you started pushing it a little and the rotor would stall. Went from running 3-4mph down to 1.5mph. It looked like the drive pulley might've been seeping a little so i did a full rebuild with new o-rings, guides, and pins and that all seems to be good now. Started beans this week and still acted the same. Cylinder speed around 750, get into a tough spot around 2.5mph and plugged the rotor without pulling the engine down. Noticed the rotor belt was a little loose as i unplugging the rotor as well. Talked to my local Gleaner dealers and they told me the hub isn't available anymore, and there isn't a parts breakdown from Agco so only option is a used one. I took their advice and pumped most of a tube of grease into the hub and ran the speed up and down, and after a few hours of cutting beans it seems to be working a lot better but still has me nervous. ![]() |
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
Posted: 17 hours 42 minutes ago at 10:03pm |
That needs to be greased DAILY without fail. If it seems to be working now, keep greasing and cycling the speed up and down fully to spread the grease around internally. If you want to disassemble completely, there will be some areas on the cams that may need to be dressed up with a grinder or a file to make them smooooth again.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8816 |
Posted: 9 hours 11 minutes ago at 6:34am |
I've had several of those apart on N series. I think these are similar. Needed a press to take them apart. Big spring in there. If you make it through harvest, I would take it apart before next harvest for sure. Definitely replace the spring. I've seen the cams break before. Either replace them, or if they're not too bad, do like doc says. Also, there is a thrust bearing in there in between two thrust washers, check them over really well. And at the very least, clean em up good, best to replace them. Could be flat spots on the little rollers, or gouges in the thrust washers
Darrel |
