Question on a D14 head |
Madkor ![]() Bronze Level ![]() Joined: 27 Aug 2015 Location: MN Points: 18 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Apr 2018 at 8:29am |
I am replacing the manifold studs. when I pulled the studs antifreeze came out of two of the short stud holes. I assume that's not normal and my head is cracked or somebody put the studs in to deep. If that is normal do you put a sealer on the studs? So just wondering what I should do next. Thanks in advance for your advise.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21959 |
Put goop on the studs and install them. Perfectly normal.
Thanks
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54198 |
X2 on perfectly normal. Put some loctite on the studs. It'll seal long enough, fer the rust to take over...
I think the generator bracket bolts do this, too...
