Pulling WD45 engine help
bigstone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigstone Quote  Post ReplyReply Direct Link To This Post Topic: Pulling WD45 engine help
    Posted: 11 Jul 2025 at 10:40am
I've read a few posts about removing the engine to replace the dry clutch.  I think got most of it pounded in my head (Maybe?)    Does it make a difference if one has a narrow front or wide font tractor? I did not find that covered in what I had read.
  I'm not removing the side channels.  I have a wide front.   Your help would be much appreciated.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 12:54pm
Hello bigstone.
The process is the same for a wide or narrow front. The wide is a little more difficult becasue you can't remove the rear angle iron that supports the front axle, but it's no problem. The oil pan just scrapes that support a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigstone Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 1:16pm
Thanks for that reply.  I just removed the radiator.  And I thought I had the hand crank rod figured out. No I don't...  Do people just cut the hand crank rod off or is there another secrete?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 1:37pm
I could be wrong, but I thought if you were to remove the four bolts per side that secure the steering box to the frame, slide it forward and reinstall two bolts in the rear holes in the steering box to the front holes of the frame it would provide clearance for engine removal. May be easier said than done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 4:48pm
Remove bracket bolt guiding hand crank shaft. Pull full fwd and grip with vice grip. You can remove steering shaft support bolt to gain a little more wiggle room. When pulling engine fwd you have to travel straight far enough to get off of clutch shaft then lop  engine to side (I don't remember which) to get by steering shaft. It's just as tricky getting back in and aligned to clutch shaft but it's possible. Experience is your teacher. Trying to remove frame bolts will likely twist some off.  GR 2 bolts. Seems like there is a roll pin in hand crank shaft by bracket that needs removed to be able to compress spring. Been awhile!
Edited by SteveM C/IL - 11 Jul 2025 at 4:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigstone Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 6:25am
Thanks guys.
Other than getting everything loose that needs to be (I think)  I'm ready to give it a go.  I also have the rail bolts loose  so I can remove the clutch pedal side rail off if needed.  I'm doing this myself.   What would you do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 8:00am
You need a good (and safe) way to lift the engine up and out of the chassis. A piece of angle iron works best.  A 2" x 2" by 1/8" thick around 16 to 18 inch long angle iron will fit. Remove the four nuts that hold the valve cover on. Drill 4 holes in your angle iron on one side to slide down over these valve cover studs. Keep your holes close to the "bend" of the angle iron, not out on the edge. Reinstall the nuts so they are more than 50% threaded on the studs. Now attach a lifting chain to the vertical part of the angle iron making your balance point an inch or so towards the flywheel as it is the heavy end. Maybe make several chain attach holes so you can adjust things if needed.  My 24 inch long chain attaches to just rear of the front stud and just ahead of the rear stud in a loop on the vertical part of the angle iron. Place the chain to the inside to get close to centering over the valve cover studs. It doesn't take a heavy chain to do this. If a 3/8" bolt will just slide thru a chain link it is heavy enough. Have fun and don't get hurt.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2025 at 11:05pm
it will come out  with out taking the frame apart you will need to undo the steering shaft at the u joint  and twist the front ofthe engine over a little so the backk of the block will clear the frame rails   i just did this with a wc  last week
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:26am
DO like Dr said. A cheery picker or overhead hoist works best so you can wiggle and go slow. One of these levelers work great so you can tip it forward and back a little
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigstone Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:55am
I'm sure getting a lot of good advice here. Much thanks to all.
I do have a cherry picker and will look for a leveler. Planning on making the angle iron bracket like Dr. Allis said. hopefully today.
Right now I'm stuck on splitting the universal joint.  I have 1 pin removed (one closest  to the front end and the other one is buggered up real bad.  I should be able to separate them??  May need a bigger hammer.
Please continue to give me hope!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 3:36pm
Remove TOP pin. Turn the steering wheel clockwise three or four turns while pulling up. Leave U-joint alone.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2025 at 6:17am
The engine will come out with the steering shaft in place. You will need a longer pry bar and more paint will be scratched.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigstone Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 54 minutes ago at 10:12am
Sorry Guys,  Back on task now.   I borrowed a cherry picker leveler.  I did not separate the U joint because the one pin that Dr Allis said I should remove looked like mushrooms on the ends and I had already remove the other pin.
On last question regarding the  hand crank shaft.  I didn't  remove the  pivoting pin on the end of the shaft. Do I need to do that?  I'm ok torching off the shaft if need be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 60 minutes ago at 3:06pm
NO! Remove the middle pin and unbolt the guide bracket then pull fwd and lock it with vise grip out on the front of casting. I said this once already.
