Print Page | Close Window
Charging a B
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=49390
Printed Date: 24 Aug 2025 at 10:53pm
Topic: Charging a B
Posted By: EPALLIS
Subject: Charging a B
Date Posted: 22 Apr 2012 at 12:40am
It appears the battery is dead on my model B.  A couple questions.
1.  It's a 6 volt.  When I connect the charger should the charger be set on 6 volt or 12 volt?
2.  When charging, should the battery be always taken out or can I hook the cables up with the battery left in the battery box with the terminals still connected?
Thanks in advance for any assistance.  Going orange is going great!
Posted By: Lance/SC
Date Posted: 22 Apr 2012 at 4:33am
I'll be interested in seeing the replies to this.  On my 6 volt CA I always charge it on 6 volts and take the cables off the battery since it's a positive ground system.  Then I can charge it the normal way without worrying about anything.
Posted By: R.W
Date Posted: 22 Apr 2012 at 9:23am
I set mine to six volt 2 amp and leave the battery hooked up, put the positive cable on the positive terminal and the negative cable on the negative terminal of the battery.
Posted By: CTuckerNWIL
Date Posted: 22 Apr 2012 at 9:32am
If it is the original positive ground htere is no reason to disconnect the battery. Put the charger on 6 volts cause that's what you are charging. Connect the negative clamp to the NEG post on the battery and connect the positive clamp on a good ground away from the battery.
