Print Page | Close Window
G engine question
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=153789
Printed Date: 29 Oct 2025 at 9:49am
Topic: G engine question
Posted By: MNLonnie
Subject: G engine question
Date Posted: 08 Sep 2018 at 9:21am
Went to fire up the G the other day and heard a metallic snap and then it had no compression. I assumed broken camshaft/timing gear or something but this morning I pulled it in the shop and all 4 intake valves are stuck open and all 4 exhaust valves are working fine. Before I tear it apart I would like to know what would cause this?
Posted By: Tracy Martin TN
Date Posted: 08 Sep 2018 at 7:20pm
If the exhaust are opening and closing, I would bet the intake are stuck from water.They all shouldn't be stuck at completely open unless rust has seized them after you turned engine over. With the cover off you should be able to inspect the valve stems. Try some kroil and see it they will free up.Hth  Tracy
Posted By: JoeM(GA)
Date Posted: 08 Sep 2018 at 7:32pm
Like Tracy said, rust has formed on intake stems, first time they opened
the rust dug in to the guides and they all stuck in succession
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
