Power Steering issue
jpi72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpi72 Quote  Post ReplyReply Direct Link To This Post Topic: Power Steering issue
    Posted: 2 hours 56 minutes ago at 9:25pm
I have what I believe is a 610 Allis Chalmers forklift.  It has a D15 Series 2 engine (160 cu. in.)  When I start the forklift the power steering is really hard to turn.  It takes quite a while of warm up before it works properly.  The forks lift right away.  Do you have any suggestions?  Am I getting air into the system when it sits overnight?
Joel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 35 minutes ago at 9:46pm
In January of 2025 you said: "we do not suspect the pump".  Back then, I told you I thought it was the pump. Yesterday, I again told you I thought the pump was losing its prime when it sits.  I am visualizing a single TANDEM (twin) pump that has a problem in the power steering section and it may be at the driveshaft end of the pump, pulling air thru the shaft seal.
