power steering failure
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: power steering failure
    Posted: 17 Jun 2025 at 6:18pm
AC-D15 II power steering suddenly failed to function. has always been greased properly. has been occasionly low on hydrlicaulic steering oil.   diagnosis??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2025 at 7:35pm
Remove the grille screen. Remove the power steering breather and check the oil level. If you can see the oil just above the steering gear inside that is full enough. Start the engine and throttle it up about half-way. If the pump is working at all, the oil will be moving around when you look into the hole with a flashlite. No oil movement whatsoever means a failed power steering pump I would say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2025 at 5:26pm
I see you were using your D-15 II today??    Power steering fixed ??
This page was generated in 0.110 seconds.
