power director leak 17 iv
Brian NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian NC Quote  Post ReplyReply Direct Link To This Post Topic: power director leak 17 iv
    Posted: 19 Mar 2011 at 9:03pm
The power director is leaking at the lever. Can o-rings be replaced with out splitting? If so where can I purchase?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 9:54pm
Remove the handel on right side, remove snapring on left side. Slide shaft to right just enough to remove oring, install new oring then slide shaft to right and do the same.
 Orings are a standard oring or go to a agco dealer.   MACK
This page was generated in 0.313 seconds.
