Power Director clutch discs |
Brad1
Topic: Power Director clutch discsPosted: Yesterday at 4:25pm |
Hello all, 1961 D15 series 1, I would like to know if anyone has used power director clutch disc for sale. At the moment new discs are not affordable for us right now. Any leads would be greatly appreciated too. Thanks guys
Posted: Yesterday at 6:36pm |
If you brought me your Power Director clutch and said "rebuild it like it was your own", I almost for sure probably wouldn't replace ANY drive discs or separator plates. Not saying that I absolutely wouldn't, but highly doubtful;. You'd have to have the clutch run dry on oil or be so badly shimmed by someone who had no idea what they were doing to warrant their replacement. If those parts aren't warped, they are probably good for re-use. I would replace C-clips as needed, all the six rollers and most probably the two ramp plates. The Low and High drive hubs if badly worn would be considered for replacement t. That's it. So, why do you think you need all 7 drive discs??
Brad1
Posted: 13 hours 14 minutes ago at 10:17am |
Thanks for your quick and honest reply. After a lengthily explanation my response to you was deleted by a "system error" whatever that means. So ill post a few pics instead.
Brad1
Posted: 12 hours 59 minutes ago at 10:32am |
I'll try again, yes low oil and the shims were way out of spec. long and short were used in the center location, huge gap. A few clutch linings are at or beyond the ware indicators and a few are gouged. High temp discoloration on a couple of them. The brass collar let go and made a real mess, a nut from the collar bolt must have gotten in between the brass collar and the slipper tube (I call it) and wiped out the cog on the slipper tube. I never found the one missing nut after a very thorough search. I have a replacement brass collar and the cast piece that activates it. Also have a clutch housing with the engagement linkage on the way. I'm learning as I go on this one.
![]() ![]() ![]() ![]() Edited by Brad1 - 10 hours 32 minutes ago at 12:59pm |
Posted: 12 hours 26 minutes ago at 11:05am |
You could settle for a D-14 clutch (identical) or a D-17/19 clutch (almost identical) and wind up with all the parts you will need.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3997 |
Posted: 10 hours 34 minutes ago at 12:57pm |
you might just as well look for a used one
Brad1
Posted: 10 hours 25 minutes ago at 1:06pm |
Ok I put a few pics, the clutch plates are not all that bad I guess. The grooves in the plate are exaggerated by the pic. I can just grab the indentation with my thumbnail. Am I trying to fool myself or is unacceptable condition to use this tractor for brush hogging a few times a year for 2 1/2 acres. Been using it all along with no PD as it is.
Edited by Brad1 - 6 hours 55 minutes ago at 4:36pm |
Posted: 9 hours 42 minutes ago at 1:49pm |
Ramp plate(s) pockets for the rollers that look like those will surely jump out of engagement when the engine is running wide open throttle. I see it has two different driving disc styles, which means someone has been in there before. A missing nut ?? Have you removed the tin pan under the PTO drive gear area? which is just ahead of where this clutch is located. What I see, if the discs and steel plates aren't warped, they will work as-is. Get it shimmed properly with new ramp plates and keep 2+ gallons of oil in it and you'll be fine.
Brad1
Posted: 6 hours 44 minutes ago at 4:47pm |
The other ramp plate is worn more than the first ramp plate I posted. Yes clearly someone was into this and really made a mess of things. At this point I would have to have new ramp plates in your opinion? Could they be built up with weld and put on a surface grinder then touch up the ramps with a small die grinder? Have you heard of such a thing? Good used ones are probably non existent?
Posted: 6 hours 29 minutes ago at 5:02pm |
That is JUNK. and is the cause of the hand levers jumping into neutral when you throttle the engine up to wide open. Sooo, the inexperienced shade tree wrench feels quite safe in thinking he can "shim" things around to make it stop jumping out, which doesn't work. A & I used to have them. I've never had any built up, so I have no experience on that. If you do, remember every time you snap the lever into engagement, that's one more time closer to being worn out it is. If you could find a PTO clutch out of a D-21, they might be pretty nice, as that clutch may not have been used much at all over the years.
Brad1
Posted: 6 hours 11 minutes ago at 5:20pm |
Thanks Doc I do appreciate your quick reply and knowledge. I will look around for the D21 pto ramp plates as you've suggested, if I can't find anything or nobody has good plates for sale on this site I might not even reinstall the PD and list the parts I've already bought on ebay. This tractor is pretty ruff, runs great, I got the traction control working again, without the PD working it still pulls a 3 bottom and an 8' disc on hilly terrane with no problem.
Posted: 5 hours 57 minutes ago at 5:34pm |
A good deal of more popular models that use those ramp plates, LOW side is usually always in much better condition than HIGH side. Why?? ..........who uses Low side that much ??
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5200 |
Posted: 4 hours 15 minutes ago at 7:16pm |
I should have a used Power-Director from a D15 around here. I'll look tomorrow.
Edited by PaulB - 4 hours 15 minutes ago at 7:16pm |
