Points for a d19 |
cnafarms ![]() Silver Level ![]() ![]() Joined: 01 Jul 2011 Location: Mt. Airy, MD Points: 140 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Jun 2017 at 6:16pm |
Have a D19 just died today. Replaced coil still nothing. Getting plenty of fuel no spark. My question is will points from a D17 work. Went to tsc what a joke they are but they had points for an Allis 190 will they work. Just need it to run for couple hours to get done round baling then I was going to put electronic ignition in it. Oh before it shut off started missing. Like I said has plenty of fuel flow out of bowl. Just was wondering bout points from a D17 or 190 and if they'll work on it.
Thanks |
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1778 |
How about the condenser?
orange-is-power ![]() Silver Level ![]() ![]() Joined: 04 Dec 2011 Location: Kentucky Points: 364 |
My vote is for the condensor, too. I do believe D19 tune up kits are the same as the WD45/D17, etc. 190 kit is different.
So a condenser off a d17 will work. That's what I was looking for. Thanks for the input
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Do you have voltage at the coil with the ignition turned on? Look there first. You might have a bad ignition switch.
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6464 |
If you have the electronic ignition kit on hand you can install it as quickly as you can change the points and condensor. Steve at B&B Custom Circuits has the good points and the electronic ignition kits or you can try NAPA for the points and condensor, don't buy the cheap junk from TSC.
Edited by Hubert (Ga)engine7 - 12 Jun 2017 at 9:10pm |
