Pertronix Ignition Quit Again
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: Pertronix Ignition Quit Again
    Posted: 08 Apr 2017 at 5:14pm
I've had nothing but trouble with my electronic ignition and I can't figure out the problem. Today at plow day my ignition burned out again!! This is the 3rd time. Thank goodness I pack my points with me. I have the correct ohm coil, 12v system, charging at 14v with no spikes that I can tell. I have copper core wires still is that burning them up or am I just having bad luck? Also running 295 plugs if that matters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 5:22pm
Man I feel for you, though 3 of them ??Have  to admit if I used my D-14s more, I'd toss electronic ignitions in them , but nothing 'off the shelf'. I designed/built them 30-35 years ago and figured out how to bullet proof them. To me it's really sad the commercial ones can and do fail as electronic 'bits nd pieces' are a lot cheaper today than 3 decades ago.
Hopefully you'll stick with good old points for now ??
Jay
cwhit View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 6:33pm
Pertronix has a hotline. I,ve used them before. They are VERY helpful. Tech person will walk you through ways to check your system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 6:45pm
I've already did that with the last 2. I've turned 2 in on warranty and they covered it. I don't understand what is going on unless it's just junk parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 7:30pm
You must be getting the lemons or there's something that your not finding. I've put them in everything I've owned with points for more than 20 years and not once had any problem. I've used them with solid copper wires and sometimes the coil that was already on the tractor.
Edited by PaulB - 08 Apr 2017 at 7:42pm
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 7:35pm
I believe you're not supposed to use solid copper spark plug wires.
Hope I have better luck I just bought four of them.
Thanks & God Bless
Dennis
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 8:13pm
Call Steve at B & B custom circuits. There must be something like a bad crimp on the cables to the key switch maybe. SteveNJ is his handle in here he knows these electronic systems as well as anyone else.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 8:27pm
I have stock 6 volt system on my WD45 and stock points as well. I use Mallory 8mm wires for the spark plugs. Works awesome. Starts in any temp with no block heater. Make up your own so length is correct. Very neat application.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 8:44pm
Transistor ign. really don't work very good on most tractors.---It's designed for v-8 race cars.----UNLESS you make your own for YOUR application!---Not hard to make!---ME,----I stick to good ole' points , LOTS less trouble!!!! lol!!! thanks; ac fleet
orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:01pm
    My question on pertronix is my coil runs so hot can't hold onto it. Seems to work ok is that normal? I have pertronix wires ,coil and the ign. system. checked voltage.
                                 thanks Terry
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:22pm
Should use spiral core wires with electronic ignition, only magnetos have to have copper core. Are you turning the engine off with the key or a kill switch? Or otherwise leaving the key on with the engine off? The label on the module under the cap is supposed to burn off if the module overheats and burns out. Leaving the key on with engine off is the main culprit of this. Check all your wires, make sure connections and grounds are solid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:25pm
I use to always say stay with points but after trying the electronic ignition there is a difference in the way it runs. I just gotta figure out why they keep burning up.
When I went to start it this morning to unload for plow day it cranked right up as usual. Let it run to warm up and it quit and wouldn't restart. Put my points back in and it fired up. Steve rebuilt my distributor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:28pm
12 volt system needs a 3 ohms coil. If the coil is getting hot I would suspect that the coil is either not 3 ohms or there is a bad wire somewhere in the circuit or the key switch is flaky and needs to be replaced. I had a pertronix module burn out because of a bad key switch. The other question is are you positive or negative ground? The electronics in the negative ground system are less likely to burn out just the nature of the circuit in the two systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:31pm
Negative ground. All wiring and ignition switch are 3yrs old. Coil is correct ohm I checked it. What should I do to see if something is going on with ignition switch?
Edited by 79fordblake - 08 Apr 2017 at 9:38pm
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 2:41am
I feel for you, but I dont know what to say. Ive converted about 15 engines I think, never had any issues, and some of the engines converted never ran so good. Hope you figure it out, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:53am
We sell the "Ignitor" module kit, and that seems to work fine with most Solid Core wires, but here's the reason for some Ignitior units burning out. Leakage. Leakage from the spark plug wires themselves. Some say its from EMI blowing out the hall effect module. Its not. And, its greater when equipped with a higher volt coil. As spark plug wires "age" they can start leaking current out of them. This happens to the best plug wires out there on the market. Doesn't matter. Eventually, they fail. This current can actually "spike" the E.I. module taking it out. The reason is the current when leaked can find a ground path which causes a large voltage spike which can take out the module. Pertronix prefer's you not to use solid core wires because some of the failures are from "worn or aged" solid core spark plug wires from their testing, especially if you are using the "Ignitor II". That unit is quite a bit more sensitive and that should have suppression wires used with it always! As Chuck mentioned, Pertronix's tech line is great!
My suggestion is to inspect the spark plug wires carefully for any breaks in the jacket where current could expose itself causing the problem. I'm thinking you have a leak issue with the wires. They're 3 years old now, and being out in the elements on a Tractor increase the age two fold. Sun, moisture, heat, etc. I would either replace the spark plug wires with a new set of solid core wires or being its a Distributor fired unit, install a set of suppression wires to cut down or eliminate the spikes that could occur. This may eliminate your E.I. module issues all together. After all, those things aren't cheap, but they do last a looong time! The unit in my 6V model B is going on 18 years old now. I build the suppression style wire sets as well as the solid core versions. One other suggestion I would like to add is if you have a Distributor fired Tractor and the Spark Plug side of the wires does not have a boot, I suggest sliding boots over the plugs to keep any current from spiking off the plug to ground causing a high voltage spike. This also insures the plug terminal is covered and insulated. Its nice to have the OEM look, but its better to have the reliability! Your call there.....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 11:46am
Steve, the spark plug wires are probably only a year old and I bought them from you, you also rebuilt my distributor. I checked my coil again and it is 3.6ohm. Just to give it a shot how much are the suppression wires you make?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 8:32pm
I'll build a suppression set of wires for ya no charge Blake. Try em' out and see if it eliminates the problem. What model Tractor do you have? Was that a WD45? I don't remember... BTW, the ohm reading is a tick on the high side.  Should be 2.7-3.3.
Steve
Edited by Steve in NJ - 09 Apr 2017 at 8:35pm
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 9:27pm
Also: 3.2 ohms doesn't necessarily mean the coil is good. Coils can look good when cold and short out between windings when hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 3:51am
Yes it's a WD45. The Pertronix instructions say 3ohm or more for 4 cylinder. The coil is only a couple months old. The tractor ran good the rest of the day. All I did was put points back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 7:10pm
If you think your EI module is bad, which it certainly seems that way since it ran good with points, you best replace that before trying Steve's wires or anything else- otherwise you're just masking the effect of the new part. If the module is bad, it's bad and anything you try to do will seem as if it doesn't work. I really think it's your key/shutoff switch given the age of your wires and coil.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 9:54pm
my one customer has the pertronics on his v4 wisconsins on his target concrete saws  they have copper wires and run hard many hours per day in all kinds of weather without ignition problems .    so this thread has really got me interested as to the problem because i just biult him anew engine and it has new copper wires and i was going to use the distrubutor with the pertronics out of the one i am replaceing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 4:00am
I didn't know wiring and a key switch would be considered old after 3 years? Heck the wiring was 30yrs old before I replaced it all. I have to send the module off Pertronix wants to look at it. Not sure yet but I may just forget about the electronic ignition. 3 replacements in about a year is enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 4:19am
Three modules in less than a month (Petronix) for me was enough, went back to points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 4:46am
I'll have to take a look at my switch this weekend and see about replacing it I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 6:31am
The problem with the key switch is there are just a lot of junk ones sold out of china. I think the contacts are made for AC not DC. Big difference in cost of the contact pad material because of how DC wants to make a arc. I have had to toss a key switch which was only 6 months old because it would drop the voltage going across it and under voltage the pertronix kit. If the spade terminal on the switch is a little loose you can get voltage spikes ad it wiggles that cause trouble. I miss the old switches that had a screw holding the wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 10:22am
While you're at it, check your ground connections. A bad ground could cause more problems than a bad ignition switch.
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 2:28pm
Steve at B&B has the best ignition switches I have seen.  Others sell them too, probably.
Roscoe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 5:40pm
Both of my gas tractors have both a Pertronix and a heavy duty 75 amp push pull toggle switch. The Oliver has had the same Pertronix for 14 years, the CA for 20 years. All I used for wires were a good quality suppression wire set for a 4 cyl car. Farm store cheap wires aren't worth paying money for. If you've been using good wires and Pertronix's coil, I'd be wondering if your ignition switch is not making good contact or your charging system is spiking the system.
Pollak Switch
Edited by Brian Jasper co. Ia - 13 Apr 2017 at 5:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 3:19pm
I have a switch and wires on the way from Steve. I ended up not messing with it this weekend. Maybe next week.
This page was generated in 0.103 seconds.
