Paint and adjustable front axle
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Paint and adjustable front axle
    Posted: 20 Jun 2012 at 9:37pm
Adjustable front axle painting, what to prime and paint?
Wide front 1948 C. I will be disassembling it because tie rod end rubber is shot.
Paint outside of outboard tube (usually a solid bar of steel)? Seems reasonable.
Prime/ Paint inside the center tube? How? With a mop or sponge?
If a tight fit, don't paint anything where tubes overlap?
If not, then what, grease up the inside of tube? Just paint outside after reassembly?
I guess same questions could apply to the tie rods.
Thanks
