Old Trucks, just keep on Giving!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Old Trucks, just keep on Giving!!
    Posted: 07 Nov 2024 at 6:24pm
Ride to Minneapolis to get the New To Us Living Quarters trailer the wife was groaning about the Right WS Glass, had Etch from a bad blade, and was starting to smoke a bit.  Had bought the seal, had intended to have a WS Service come and change them both but alas bought the two glasses and installed ourself HERE.  Then to kick me in the teeth a Little Harder, the starter on my newly recovered Super Duty that I had CONSIDERED should be changed during the big work, gave up.
KW
The Worst of two WS
Both got replaced with a New Seal
Ran out of time and left lock strip out a few days.
Once was back in and Glasses cleaned.
Then that 25 year old Finally Gave It Up 7.3 Starter, Got my $$$ Worth from that one!!
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 8:41am
Have all new glass for my B-61 once I decide to get off my duff and put it back on the road. Near every piece has been opaque around the perimeter for many years and scratched up.The wing windows are bubbled and yellowed in the center which is typical of glass that old, (1957).
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2024 at 6:05pm
Uncertain How the previous owner slipped this to FedEx but this arrived as a shipped 30# Package.  Closer to 130#.  Now to set up and install a slide out 'Drawer' for it in the rear Trailer side compartment.  1" Square steel, angle iron and 200# Slider Rails should do the trick attached to the internal trailer framing.  That will give plenty of Air for cooling, engine op and ability to exhaust Outside of Trailer.
Some slight Fiberglass scuffs, a little resin and those will be fine.  Noted as Less Than 110 service hours.  Now need to buy 20# Cylinder and hose/regulator assembly, then wire in either hard wired or to a side installed outlet and just plug in as would Outside Electrical service.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 8:18am
Doesn't your Gen. already have a 30 amp. RV Receptacle?
I bot a 2,000 Watt Honda Gen about 15 years ago for RV boondocking when travelling.
A standard 30 amp. RV Power Chord off the shelf connects the RV Factory Connection to the Gen.
Small adapters are available to convert the the 30 amp RV chord to 20 amp.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2024 at 12:53pm
Trailer does, with that can add a plug in for the Gen as it is designed hard wire, three wire pigtail hanging by LP cut off hose.
