Off color air condition question
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Topic: Off color air condition question
    Posted: 08 Jun 2022 at 9:44am
Friend has a MF 4243 cab tractor and he thinks it needs some freon added. This tractor was made from 1998 thru 2001. Does anyone know what year tractors came with R134A freon?  Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 9:49am
If was 134 factory it will have 134 fittings. If it has 134 adapters on 12 ports its been switched. It is possible to charge 134 through 12 fittings if you the right pieces.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 11:01am
Steve, that should be 134a.It became the standard in the mid 90s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 12:47pm
...I didn't stick the "R" in there either....picky,picky
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2022 at 1:49pm
as Steve mentioned......... R12 are SCREW on fittings... R134a is Quick Disconnect
Edited by steve(ill) - 08 Jun 2022 at 1:51pm
This page was generated in 0.111 seconds.
