No oil pressure on a C |
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2033 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Jun 2019 at 6:35am |
Bought a C. Non-running, just the way I like it. After fixing a few things I got it running but no oil pressure. After a bit was able to prime the pump and got oil pressure. Drove it around and made a few more repairs. (jumps out of third gear).
Next day while deciding the fate of this tractor I wanted to move it to a remote corner. Started it and no oil pressure again. What will I find when I get it apart?
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Have you checked the oil filter first?
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Might be missing the center tube in the filter. If so, that messes with the pressure.
WC, CA, D14, WD45
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
or could have one of those crappy filters wix made for a short while.
Wink I am a Russian Bot |
By no pressure, I meant to say no oil at all coming from the pump. After I primed it, then I had pressure. The next day no oil at all.
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
isnt there a check ball in there?
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
The shop manual could help with details:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Think about placing a drinking straw in a glass of liquid then placing a finger over the top of the straw and lifting the straw out of the liquid. You see it retains the liquid but when you remove your finger and the liquid drains out or in the oil pumps case, looses its prime. To loose its prime it has to have air to hold it finger in place to hold the oil from running back down into the oil pan so to speak. A cracked or loose stand pipe will cause it at the bottom end or to much clearance over the pump vane rotor. That can be caused from wear on the cover or a thicker gasket than around .007 under the cover. It could be in some cases the ball check in the stem but it would cause a freer flow thru the stem into the camshaft that could effect the pressure. All of which means at the very least removing the oil pan and then splitting the tractor if it is not found on the bottom side. Other than that is to prime the pump before each start. |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5103 |
Rust or a worn spot on the check ball is what I have usually found.
